thinkgeo.mapsuite.mvcedition
ThinkGeo.MapSuite.MvcEdition
MvcEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
B
  • BingMapsOverlay
    Represents an overlay object that gets images from Microsoft's Virtual Earth server.
  • BingMapsOverlaySetting
    A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
C
  • ClassBreakMarkerStyle
    This class represents a style based on class break values.
  • ClassBreakMarkerStyleSetting
    A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
  • ClientCache
    This class controls how the map images are cached by the browser.
  • CloudPopup
    Represents the popups that appear in a cloud (a.k.a. balloon) shape.
  • CloudPopupSetting
    A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
  • ClusterMarkerStyle
    A kind of MarkerStyle to filter the markers.
  • ClusterMarkerStyleSetting
    A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
  • ContextMenu
    This class represents a right-click shortcut menu used in the map control.
  • ContextMenuItem
    This class represents a menu item of the ContextMenu control.
  • ContextMenuItemCollection
    A collection of ThinkGeo.MapSuite.MvcEdition.ContextMenuItem objects.
  • ContextMenuItemSetting
    A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
  • ContextMenuSetting
    A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
  • CustomPopup
    Represents a pop up window whose style and background can be customized.
  • CustomPopupSetting
    A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
E
F
  • FeatureOverlay
    Serves as the base class for the overlays that contain features and paint the features at client side.
  • FeatureOverlaySetting<TOverlay,TSetting>
    A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
  • FeatureOverlayStyle
    Specifies how the features in a FeatureOverlay are drawn at the client side.
  • FeatureOverlayStyleSetting
    A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
  • FeatureSourceMarkerOverlay
    Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
  • FeatureSourceMarkerOverlaySetting
    A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
G
H
  • HighlightFeatureOverlay
    Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
  • HighlightFeatureOverlaySetting
    A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
  • HtmlHelperExtension
    HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
I
  • InMemoryMarkerOverlay
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
  • InMemoryMarkerOverlaySetting
    A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
J
  • JsonMemberAttribute
    Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
K
  • KeyboardMapTool
    Determines whether the map can be operated by keyboard.
  • KeyboardMapToolSetting
    A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
L
  • LayerOverlay
    Represents an Overlay that contains layers.
  • LayerOverlaySetting
    A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
  • LoadingImageMapTool
    Represents a small image that displays at the center of the map when the map is loading.
  • LoadingImageMapToolSetting
    A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
  • LogoMapTool
    Represents a company logo or other logo-type image that displays in the lower right corner of the map.
  • LogoMapToolSetting
M
O
P
  • PanZoomBarMapTool
    Represents the panning and zooming panel in the upper left corner of the map.
  • PanZoomBarMapToolSetting
    A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
  • PanZoomMapTool
    Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
  • PanZoomMapToolSetting
    A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
  • PointMarkerStyle
    Represents the ordinary marker style.
  • PointMarkerStyleSetting
    A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
  • Popup
    Serves as the base class that defines the methods and properties common to all types of popups.
  • PopupSetting<TPopup,TPopupSetting>
    A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
S
  • ScaleLineMapTool
    Represents a graphic line marked with numbers indicating the map's current scale.
  • ScaleLineMapToolSetting
    A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
  • ServerCache
    This class controls the cachablity of the map control at the server side.
  • SimpleMarkerOverlay
    Represents a MarkerOverlay object to which you can add markers directly.
  • SimpleMarkerOverlaySetting
    A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
  • SingleThreadTileResource
    This is an asynchronous HTTP handler which is used to handle web map services.
T
V
  • ValueMarkerStyle
    This class allows you to match a value with data in the feature to determine how to draw the feature.
  • ValueMarkerStyleSetting
    A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
W
  • WebImage
    Represents a small image that displays on the map.
  • WmsOverlay
    Represents an overlay object that gets map images from the WMS server you specify.
  • WmsOverlaySetting
    A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
  • WmtsOverlaySetting
  • WorldMapKitWmsWebOverlay
    Represents an overlay object that gets map images from the WMS servers.
  • WorldMapKitWmsWebOverlaySetting
    A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
Structures
Enums
B
  • BingMapsStyle
    This enumeration specifies the map types available from Bing maps.
C
  • CursorType
    This enumeration determines the cursor that appears when the pointer moves over the map.
G
  • GoogleMapType
    This enumeration specifies the map types available from Google Maps.
M
  • MarkerDragMode
    This enumeration specifies how the map markers can be dragged.
  • MeasureType
    Defines the different types of the MeasureMapTool.
  • MeasureUnitType
    The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
  • MouseCoordinateType
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
R
  • ResourceDeploymentMode
    This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
T
  • TileType
    This enumeration specifies whether the overlay uses tiling.
  • TrackMode
    Defines the different modes of the EditFeatureOverlay.
  • TrackZoomMaskType
    Defines the different zoom box key code of key for the MouseMapTool.
  • TransitionEffect
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
W
Interfaces
I
  • IEntity
    The corresponding to achieve the entity object and url string between the conversion.
  • IJsonSerialization
    Define an interface to allow class that implement Json conversion.
  • IRequireId
    This interface defines an Id property that is used by the GeoKeyedCollection.
thinkgeo.mapsuite.mvcedition.txt · Last modified: 2017/03/16 21:59 (external edit)
