thinkgeo.mapsuite.mvcedition.jsonmemberattribute
ThinkGeo.MapSuite.MvcEdition.JsonMemberAttribute
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
    • System.Attribute
      • ThinkGeo.MapSuite.MvcEdition.JsonMemberAttribute
JsonMemberAttribute()
Match(Object)
IsDefaultAttribute()
MemberName
Gets or sets the name of the key part in a JSON string.
ValuePropertyName
Gets or sets which part of the property object to be serialized.
TypeId
thinkgeo.mapsuite.mvcedition.jsonmemberattribute.txt · Last modified: 2017/03/16 21:59 (external edit)
