thinkgeo.mapsuite.mvcedition.overlayswitchermaptoolsetting
ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapToolSetting
A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
OverlaySwitcherMapToolSetting(OverlaySwitcherMapTool)
  • Initializes a new instance of the OverlaySwitcherMapToolSetting class.
OnClientBaseOverlayChanged(String)
  • Set onClientBaseOverlayChanged javascript function name for Element property and retun the OverlaySwitcherMapToolSetting
  • onClientBaseOverlayChanged
    • Description:A onClientBaseOverlayChanged javascript function name for Element property
RoundedCornerColor(GeoColor)
  • Set roundedCornerColor for Element property and retun the OverlaySwitcherMapToolSetting
  • roundedCornerColor
    • Type:GeoColor
    • Description:A roundedCornerColor for Element property
BackgroundColor(GeoColor)
  • Set backgroundColor for Element property and retun the OverlaySwitcherMapToolSetting
  • backgroundColor
    • Type:GeoColor
    • Description:A backgroundColor for Element property
BaseOverlayTitle(String)
  • Set baseOverlayTitle for Element property and retun the OverlaySwitcherMapToolSetting
  • baseOverlayTitle
    • Description:A baseOverlayTitle for Element property
DynamicOverlayTitle(String)
  • Set dynamicOverlayTitle for Element property and retun the OverlaySwitcherMapToolSetting
  • dynamicOverlayTitle
    • Description:A dynamicOverlayTitle for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.overlayswitchermaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
