thinkgeo.mapsuite.mvcedition.maptool
ThinkGeo.MapSuite.MvcEdition.MapTool
Defines the properties and methods that are shared by all controls on the map.
MapTool()
  • Initialize an instance of the MapTool class.
MapTool(Boolean)
  • Initialize an instance of the MapTool class with a boolean value that indicates whether it is enabled.
  • enabled
    • Description:A boolean value that indicates whether this MapTool is enabled.
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
Enabled
Gets or sets a value that turns the feature on and off.
thinkgeo.mapsuite.mvcedition.maptool.txt · Last modified: 2017/03/16 21:59 (external edit)
