thinkgeo.mapsuite.mvcedition.measuremaptool
ThinkGeo.MapSuite.MvcEdition.MeasureMapTool
Represents the measure map tool which allows measurements for features.
    • ThinkGeo.MapSuite.MvcEdition.MapTool
      • ThinkGeo.MapSuite.MvcEdition.MeasureMapTool
MeasureMapTool()
Initialize an instance of the MeasureMapTool class.
The default MeasureType is Line, and the display system units is Metric by default, also it measures geodesic distance by default.
ToJson()
FromJson(String)
  • jsonString
MeasureType
Represents the different types of the MeasureMapTool.
MeasureUnitType
Represents the display system units for output measurements.
Geodesic
Indicate whether to measure geodesic distance.
Enabled
thinkgeo.mapsuite.mvcedition.measuremaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
