thinkgeo.mapsuite.mvcedition.keyboardmaptool
ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool
Determines whether the map can be operated by keyboard.
    • ThinkGeo.MapSuite.MvcEdition.MapTool
      • ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool
KeyboardMapTool()
  • Initializes a new instance of the KeyboardMapTool class.
  • Use this constructor to create and initialize a new instance of the KeyboardMapTool class.
ToJson()
FromJson(String)
  • jsonString
PanPixels
Gets or sets the number of pixels that are shifted by each keyboard-based panning operation.
The value of this property determines how many pixels to shift when using the arrow keys to pan.
Enabled
thinkgeo.mapsuite.mvcedition.keyboardmaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
