thinkgeo.mapsuite.mvcedition.loadingimagemaptool
ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool
Represents a small image that displays at the center of the map when the map is loading.
    • ThinkGeo.MapSuite.MvcEdition.MapTool
      • ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool
LoadingImageMapTool()
  • Initialize an instance of LoadingImageMapTool class.
ToJson()
FromJson(String)
  • jsonString
ImageUri
Gets or sets the URI of the loading image.
  • Type:Uri
Width
Gets or sets the width of the loading image.
Height
Gets or sets the height of the loading image.
Enabled
thinkgeo.mapsuite.mvcedition.loadingimagemaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
