thinkgeo.mapsuite.mvcedition.mousecoordinatemaptool
ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool
Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
    • ThinkGeo.MapSuite.MvcEdition.MapTool
      • ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool
MouseCoordinateMapTool()
  • Initialize an instance of MouseCoordinateMapTool class.
ToJson()
FromJson(String)
  • jsonString
MouseCoordinateType
Gets or sets the format that the mouse coordinates will display in.
The MouseCoordinateType property gives you two options for displaying the mouse pointer coordinates. One is in the format “longitude, latitude” and the other is in DMS format (33° 22' 15'').
Enabled
thinkgeo.mapsuite.mvcedition.mousecoordinatemaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
