thinkgeo.mapsuite.mvcedition.animationpanmaptool
ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
    • ThinkGeo.MapSuite.MvcEdition.MapTool
      • ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool
AnimationPanMapTool()
  • Initialize an instance of the AnimationPanMapTool class.
ToJson()
FromJson(String)
  • jsonString
Delay
The number of milliseconds between clicks before the event is considered a double-click.
OnClientClick
Gets or sets the client-side script that executes when you click on the map using this Animation Pan map tool.
There is a default parameter:e, which includes one parameter: “worldXY”
Enabled
thinkgeo.mapsuite.mvcedition.animationpanmaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
