thinkgeo.mapsuite.mvcedition.webconfigregistrationmode
ThinkGeo.MapSuite.MvcEdition.WebConfigRegistrationMode
This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
Items
Automatic
  • Summary:The application will register the web.config on the fly.
Manual
  • Summary:In this mode, you need to copy the code below to web.congure file … …
thinkgeo.mapsuite.mvcedition.webconfigregistrationmode.txt · Last modified: 2017/03/16 21:59 (external edit)
