thinkgeo.mapsuite.mvcedition.georesourcefactory
ThinkGeo.MapSuite.MvcEdition.GeoResourceFactory
    • ThinkGeo.MapSuite.MvcEdition.GeoResourceFactory
GeoResourceFactory()
GetHandler(HttpContext,String,String,String)
  • Returns an instance of a class that implements the System.Web.IHttpHandler interface.
  • Type:IHttpHandler
  • Description:A new System.Web.IHttpHandler object that processes the request.
  • context
    • Type:HttpContext
    • Description:An instance of the System.Web.HttpContext class that provides references to intrinsic server objects (for example, Request, Response, Session, and Server) used to service HTTP requests.
  • requestType
    • Description:The HTTP data transfer method (GET or POST) that the client uses.
  • url
    • Description:The System.Web.HttpRequest.RawUrl of the requested resource.
  • pathTranslated
    • Description:The System.Web.HttpRequest.PhysicalApplicationPath to the requested resource.
ReleaseHandler(IHttpHandler)
  • Enables a factory to reuse an existing handler instance.
  • handler
    • Type:IHttpHandler
    • Description:The System.Web.IHttpHandler object to reuse.
GetHandlerCore(HttpContext)
  • Type:IHttpHandler
  • context
    • Type:HttpContext
thinkgeo.mapsuite.mvcedition.georesourcefactory.txt · Last modified: 2017/03/16 21:59 (external edit)
