thinkgeo.mapsuite.mvcedition.editsettings
ThinkGeo.MapSuite.MvcEdition.EditSettings
Provides editing options when the EditOverlay is in EditShape mode.
    • ThinkGeo.MapSuite.MvcEdition.EditSettings
EditSettings()
  • Initialize an instance of the EditSetting class.
ToJson()
  • Returns a JSON string that contains the information for setting the edit mode at client side.
  • Description:A JSON string that is used to set the edit mode at client side.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
IsDraggable
Gets a value that indicates whether the shape can be dragged.
IsReshapable
Gets a value that indicates whether the shape can be reshaped.
IsResizable
Gets a value that indicates whether the shape can be resized.
IsRotatable
Gets a value that indicates whether the shape can be rotated.
thinkgeo.mapsuite.mvcedition.editsettings.txt · Last modified: 2017/03/16 21:59 (external edit)
