thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting
ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting
A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
ClusterMarkerStyleSetting(ClusterMarkerStyle)
  • Initializes a new instance of the ClusterMarkerStyleSetting class.
  • style
    • Description:the ClusterMarker Style which will be assigned to Element property
DistanceInPixel(Double)
  • Set distanceInPixel for Element property and retun the ClusterMarkerStyleSetting
  • distanceInPixel
    • Description:A distanceInPixel for Element property
MarkerStyle(Action<MarkerStyleCollection>)
  • Set MarkerStyle for Element property according to a method that takes MarkerStyleCollection and retun the ClusterMarkerStyleSetting
  • actionMarkerStyle
MapWidth(Double)
  • Set mapWidth for Element property and retun the ClusterMarkerStyleSetting
  • mapWidth
    • Description:A mapWidth for Element property
MapHeight(Double)
  • Set mapHeight for Element property and retun the ClusterMarkerStyleSetting
  • mapHeight
    • Description:A mapHeight for Element property
Element
thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting.txt · Last modified: 2017/03/16 21:59 (external edit)
