thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlay
ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay
Represents an overlay object that gets map images from the WMS servers.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay
WorldMapKitWmsWebOverlay()
  • Initialize an instance of the WmsOverlay class.
WorldMapKitWmsWebOverlay(String)
  • Initialize an instance of the WmsOverlay class with the overlay identifier specified.
  • id
    • Description:The identifier string used to find the overlay.
WorldMapKitWmsWebOverlay(WorldMapKitLayerType)
WorldMapKitWmsWebOverlay(String,WorldMapKitLayerType)
  • id
WorldMapKitWmsWebOverlay(String,TileType)
  • id
  • tileType
    • Type:TileType
    • Description:Whether or not the overlay uses tiling.
WorldMapKitWmsWebOverlay(String,TileType,WorldMapKitLayerType)
  • id
  • tileType
FromJson(String)
  • jsonString
ToJson()
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
Projection
Gets or sets a WorldMapKitProjection represents which projection will be used.
LayerType
MapType
TransitionEffect
Gets or sets the transition effect to use when the map is zoomed.
TransitionEffectDelayInMilliseconds
TileType
Gets or sets whether or not the WmsOverlay uses tiling.
WrapDateline
Gets or sets a value that indicates whether the overlay wraps at the date line.
OnClientAutoRefreshTick
Don't support auto tick event by default.
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
AutoRefreshInterval
  • Type:TimeSpan
Attribution
SxY=
ThY=
URY=
VBY=
OverlayType
Gets a string that indicates the overlay type.
VhY=
  • Type:Collection<Uri>
ERQ=
thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
