thinkgeo.mapsuite.mvcedition.webimageformat
ThinkGeo.MapSuite.MvcEdition.WebImageFormat
If the image is overlaid atop other images, use the PNG image format (which can use a transparent background). If you have a low bandwidth network, use the JPEG image format. You can reduce the quality of the JPEG image and make its size smaller.
Items
Png
  • Summary:Specifies the image is in the W3C Portable Network Graphics (PNG) image format.
Jpeg
  • Summary:Specifies the image is in the Joint Photographic Experts Group (JPEG) image format.
thinkgeo.mapsuite.mvcedition.webimageformat.txt · Last modified: 2017/03/16 21:59 (external edit)
