thinkgeo.mapsuite.mvcedition.maptoolsetting_tmaptool_tsetting
ThinkGeo.MapSuite.MvcEdition.MapToolSetting‹TMapTool,_TSetting›
<!– Class –> A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
Protected MethodMapToolSetting‹TMapTool, TSetting› Initializes a new instance of the MapToolSetting class.
Protected MethodMapToolSetting‹TMapTool, TSetting› TMapTool
Public MethodEnabled Boolean MapToolSetting<TMapTool,TSetting> Set isEnabled for Element property and retun the MapToolSetting
Public MethodGetType Object
Public MethodToString Object
Protected PropertyElement TMapTool MvcElementSettingBase<TMapTool,TSetting>
MapToolSetting‹TMapTool, TSetting›()
Name Type Description
Go Back
MapToolSetting‹TMapTool, TSetting›(TMapTool)
mapTool TMapTool<!– TMapTool –>
Go Back
Enabled(Boolean)
Return Type Description
TSetting<!– TSetting –> The setting of MapToolSetting itself
isEnabled Boolean<!– System.Boolean –> A boolean variable for Element property represent the setting is enable or not
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{TMapTool,TSetting} –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Element
Return Type
<!– MvcElementSettingBase{TMapTool,TSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.maptoolsetting_tmaptool_tsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
