thinkgeo.mapsuite.mvcedition.webimage
ThinkGeo.MapSuite.MvcEdition.WebImage
Represents a small image that displays on the map.
    • ThinkGeo.MapSuite.MvcEdition.WebImage
WebImage()
  • Initialize a new instance of the WebImage class.
WebImage(String)
  • imageVirtualPath
    • Description:The virtual path of the image.
WebImage(Int32,Int32)
  • imageWidth
    • Description:The width of the image.
  • imageHeight
    • Description:The height of the image.
WebImage(Int32,Int32,Single,Single)
  • imageWidth
  • imageHeight
  • imageOffsetX
    • Type:Single
    • Description:The offset X of the image.
  • imageOffsetY
    • Type:Single
    • Description:The offset Y of the image.
WebImage(String,Int32,Int32)
  • imageVirtualPath
  • imageWidth
  • imageHeight
WebImage(String,Int32,Int32,Single,Single)
  • imageVirtualPath
  • imageWidth
  • imageHeight
  • imageOffsetX
    • Type:Single
  • imageOffsetY
    • Type:Single
CloneShallow()
  • Creates a shallow copy of the current WebImage object.
ToJson()
  • Returns a JSON string that contains the information for creating a client image object at the client side.
  • Description:A JSON string that contains the information for creating a client image object at the client side.
FromJson(String)
  • jsonString
ImageVirtualPath
Gets or sets the virtual path of the image file.
ImageWidth
Gets or sets the width of the web image.
ImageHeight
Gets or sets the height of the web image.
RotationAngle
Gets or sets the rotation angle of the web image.
  • Type:Single
FontStyle
Gets or sets the style applied to the text on the image.
FontColor
Gets or sets the color of the text on the image.
TextBackgroundColor
Gets or sets the background color of the text on the image.
Text
Gets or sets the text displayed on the image.
TextOffsetX
Gets or sets the X offset of the text on the image.
  • Type:Single
TextOffsetY
Gets or sets the Y offset of the text on the image.
  • Type:Single
ImageOffsetX
Gets or sets the image's X offset.
  • Type:Single
ImageOffsetY
Gets or sets the image's Y offset.
  • Type:Single
IconImagePath
thinkgeo.mapsuite.mvcedition.webimage.txt · Last modified: 2017/03/16 21:59 (external edit)
