thinkgeo.mapsuite.mvcedition.measuremaptoolsetting
ThinkGeo.MapSuite.MvcEdition.MeasureMapToolSetting
A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
MeasureMapToolSetting(MeasureMapTool)
Initializes a new instance of the MeasureMapToolSetting class.
MeasureType(MeasureType)
Set measureType for Element property and retun the MeasureMapToolSetting
  • measureType
    • Description:A measureType for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.measuremaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
