thinkgeo.mapsuite.mvcedition.multithreadtileresource
ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource
This is an asynchronous HTTP handler which is used to handle web map services.
    • ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource
MultiThreadTileResource()
  • This is the default constructor for the TileResource class.
ProcessRequest(HttpContext)
  • Enables processing of HTTP Web requests by a custom HttpHandler.
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
BeginProcessRequest(HttpContext,AsyncCallback,Object)
  • Initiates an asynchronous call to the HTTP handler.
  • Type:IAsyncResult
  • Description:A System.IAsyncResult that contains information about the status of the process.
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
  • cb
    • Type:AsyncCallback
    • Description:The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called.
  • extraData
    • Description:Any extra data needed to process the request.
EndProcessRequest(IAsyncResult)
  • Provides an asynchronous process End method when the process ends.
  • result
    • Type:IAsyncResult
ProcessRequestCore(HttpContext)
  • context
    • Type:HttpContext
BeginProcessRequestCore(HttpContext,AsyncCallback,Object)
  • Type:IAsyncResult
  • context
    • Type:HttpContext
  • cb
  • extraData
EndProcessRequestCore(IAsyncResult)
  • result
    • Type:IAsyncResult
IsReusable
Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance.
thinkgeo.mapsuite.mvcedition.multithreadtileresource.txt · Last modified: 2017/03/16 21:59 (external edit)
