thinkgeo.mapsuite.mvcedition.clientcache
ThinkGeo.MapSuite.MvcEdition.ClientCache
This class controls how the map images are cached by the browser.
    • ThinkGeo.MapSuite.MvcEdition.ClientCache
ClientCache()
  • Initializes a new instance of the ClientCache class.
ClientCache(TimeSpan)
  • Initializes a new instance of the ClientCache class with the specified expiration time.
  • duration
    • Type:TimeSpan
    • Description:The amount of the time that the cached images are to remain in the browser cache.
ClientCache(TimeSpan,String)
  • Initializes a new instance of the ClientCache class with the specified expiration time and cacheId string.
  • duration
    • Type:TimeSpan
  • cacheId
    • Description:A string that the browser uses to retrieve a cached image.
ToJson()
  • Returns a JSON string containing the CacheId that will be part of the request string.
  • Description:A JSON string that contains the CacheId.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
Duration
Gets or sets the expiration time of the images in the browser cache.
The Duration indicates the length of time that images will remain in the browser cache before expiring. The default value is 7 day.
  • Type:TimeSpan
CacheId
Gets or sets a string that enables the browser to cache images, and which is also part of the key for the browser to distinguish between each cached image.
Setting the CacheId will enable the browser to cache the map images. The CacheId string will also be appended to the URL of the image. The browser uses the URL as the key to retrieve a cached image; thus, you can make the browser cache different images by setting the CacheId to different values. For example, you can set a different CacheId for requests with different parameters and the browser will cache the different images for those requests.
thinkgeo.mapsuite.mvcedition.clientcache.txt · Last modified: 2017/03/16 21:59 (external edit)
