thinkgeo.mapsuite.mvcedition.loadingimagemaptoolsetting
ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting
A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
LoadingImageMapToolSetting(LoadingImageMapTool)
  • Initializes a new instance of the LoadingImageMapToolSetting class.
  • mapTool
ImageUri(Uri)
  • Set imageUri for Element property and retun the LoadingImageMapToolSetting
  • imageUri
    • Type:Uri
    • Description:A imageUri for Element property
Width(Int32)
  • Set width for Element property and retun the LoadingImageMapToolSetting
  • width
    • Description:A width for Element property
Height(Int32)
  • Set height for Element property and retun the LoadingImageMapToolSetting
  • height
    • Description:A height for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.loadingimagemaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
