thinkgeo.mapsuite.giseditor.featurelayerplugin
ThinkGeo.MapSuite.GisEditor.FeatureLayerPlugin
<!– Class –>
Public MethodFeatureLayerPlugin
Public MethodApplySettings StorableSettings Plugin Applies the settings to this plugin.
Public MethodGetFeatureSimpleShapeType FeatureLayer
Public MethodGetLayerListItem Layer LayerPlugin This method gets a hierarchy object to build the layer list tree.
Public MethodGetLayerType LayerPlugin Gets the type of the layer. GisEditor will use this method to find a match plugin to create a specific layer instance.
Public MethodGetLayers GetLayersParameters LayerPlugin
Public MethodGetLayers LayerPlugin This method creates layers instance. In this method, it might popup a dialog to configuration. For example, a ShapeFileFeatureLayer is based on a shapefile, we need popup an OpenFileDialog to choose a file. Or MSSql layer needs a connection string to connect to the server, etc.
Public MethodGetPropertiesUI Layer LayerPlugin Gets an UI that holds information of the pass layer.
Public MethodGetSettings Plugin Gets plugin settings to save.
Public MethodGetSettingsUI Plugin Gets an UI that configures settings.
Public MethodGetStyleBuiderUI
Public MethodGetType Object
Public MethodGetUri Layer LayerPlugin Gets the name of passed layer
Public MethodGetViewDataUI
Public MethodLoad Plugin This method raises when load this plugin.
Public MethodToString Object
Public MethodUnload Plugin This method raises when unload this plugin.
Protected MethodApplySettingsCore StorableSettings Plugin Applies the settings to this plugin.
Protected MethodGetFeatureSimpleShapeTypeCore FeatureLayer
Protected MethodGetInternalProj4ProjectionParameters FeatureLayer
Protected MethodGetInternalProj4ProjectionParametersCore FeatureLayer
Protected MethodGetLayerListItemCore Layer LayerPlugin(overriden) This method gets a hierarchy object to build the layer list tree.
Protected MethodGetLayerTypeCore LayerPlugin Gets the type of the layer. GisEditor will use this method to find a match plugin to create a specific layer instance. This is the core method of public Type GetLayerType() for override.
Protected MethodGetLayersCore GetLayersParameters LayerPlugin This method creates layers instance. In this method, it might popup a dialog to configuration. For example, a ShapeFileFeatureLayer is based on a shapefile, we need popup an OpenFileDialog to choose a file. Or MSSql layer needs a connection string to connect to the server, etc.
Protected MethodGetPropertiesUICore Layer LayerPlugin(overriden)
Protected MethodGetSettingsCore Plugin Gets plugin settings to save.
Protected MethodGetSettingsUICore Plugin Gets an UI that configures settings.
Protected MethodGetStyleBuiderUICore
Protected MethodGetUriCore Layer LayerPlugin Gets the name of passed layer
Protected MethodGetViewDataUICore
Protected MethodLoadCore Plugin This method raises when load this plugin.
Protected MethodOnGettingLayers GettingLayersLayerPluginEventArgs LayerPlugin
Protected MethodOnGottenLayers GottenLayersLayerPluginEventArgs LayerPlugin(overriden)
Protected MethodSaveInternalProj4ProjectionParameters FeatureLayer, String
Protected MethodSaveInternalProj4ProjectionParametersCore FeatureLayer, String
Protected MethodUnloadCore Plugin This method raises when unload this plugin.
Public PropertyAuthor String Plugin Gets or sets author information for plugin.
Public PropertyDescription String Plugin Gets or sets description for plugin.
Public PropertyExtensionFilter String LayerPlugin Gets or sets the extension filter that allows to create a specific layer.
Public PropertyId String Plugin Gets the identify of plugin.
Public PropertyIndex Int32 Plugin Gets or sets the index of the plugin.
Public PropertyIsActive Boolean Plugin Gets or sets a value indicating whether this plugin is active.
Public PropertyIsRequired Boolean Plugin Gets or sets a value indicating whether this plugin is required.
Public PropertyLargeIcon ImageSource Plugin Gets or sets large icon for plugin.
Public PropertyName String Plugin Gets or sets the name of plugin.
Public PropertySmallIcon ImageSource Plugin Gets or sets small icon path for plugin.
FeatureLayerPlugin()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this plugin.
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
Boolean<!– System.Boolean –>
GetFeatureSimpleShapeType(FeatureLayer)
SimpleShapeType<!– ThinkGeo.MapSuite.GisEditor.SimpleShapeType –>
featureLayer FeatureLayer<!– ThinkGeo.MapSuite.Core.FeatureLayer –>
<!– ThinkGeo.MapSuite.GisEditor.FeatureLayerPlugin –> Go Back
Int32<!– System.Int32 –>
GetLayerListItem(Layer)
LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –>
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer list item to build the layer list tree.
<!– ThinkGeo.MapSuite.GisEditor.LayerPlugin –> Go Back
GetLayerType()
Type<!– System.Type –> A type of subclasses that inherit from ThinkGeo.MapSuite.Layer.
GetLayers(GetLayersParameters)
Collection<Layer><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Layer} –>
getLayersParameters GetLayersParameters<!– ThinkGeo.MapSuite.GisEditor.GetLayersParameters –>
GetLayers()
Collection<Layer><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Layer} –> A set of specific layers that created by this plugin.
GetPropertiesUI(Layer)
UserControl<!– System.Windows.Controls.UserControl –> An UI that holds information of the pass layer
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer that to build the UI.
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Plugin's settings to save.
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
GetStyleBuiderUI()
StyleBuilderWindow<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderWindow –>
GetUri(Layer)
Uri<!– System.Uri –> The path file name of this layer.
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer to get path file name.
GetViewDataUI()
Load()
String<!– System.String –>
Unload()
ApplySettingsCore(StorableSettings)
GetFeatureSimpleShapeTypeCore(FeatureLayer)
GetInternalProj4ProjectionParameters(FeatureLayer)
GetInternalProj4ProjectionParametersCore(FeatureLayer)
GetLayerListItemCore(Layer)
<!– ThinkGeo.MapSuite.GisEditor.LayerPlugin(overriden) –> Go Back
GetLayerTypeCore()
GetLayersCore(GetLayersParameters)
GetPropertiesUICore(Layer)
GetSettingsCore()
GetSettingsUICore()
GetStyleBuiderUICore()
GetUriCore(Layer)
GetViewDataUICore()
LoadCore()
OnGettingLayers(GettingLayersLayerPluginEventArgs)
e GettingLayersLayerPluginEventArgs<!– ThinkGeo.MapSuite.GisEditor.GettingLayersLayerPluginEventArgs –>
OnGottenLayers(GottenLayersLayerPluginEventArgs)
e GottenLayersLayerPluginEventArgs<!– ThinkGeo.MapSuite.GisEditor.GottenLayersLayerPluginEventArgs –>
SaveInternalProj4ProjectionParameters(FeatureLayer, String)
proj4ProjectionParameters String<!– System.String –>
SaveInternalProj4ProjectionParametersCore(FeatureLayer, String)
UnloadCore()
Author
Return Type
Description
Return Type
ExtensionFilter
Return Type
Id
Return Type
Index
<remarks> Plugins are orded by this property. </remarks>
Return Type
IsActive
Return Type
IsRequired
Return Type
LargeIcon
<remarks> Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource. </remarks>
Return Type
ImageSource<!– System.Windows.Media.ImageSource –>
Return Type
SmallIcon
Return Type
GettingLayers
Event Arguments
Event Arguments
GottenLayers
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.featurelayerplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
