<!– Class –>
*System.Object ThinkGeo.MapSuite.GisEditor.LayerListItem *ThinkGeo.MapSuite.GisEditor.StyleLayerListItem
LayerListItem | Initializes a new instance of the class. | ||
LayerListItem | Object | Initializes a new instance of the class. |
MemberwiseClone | Object | ||
OnPropertyChanged | String | Called when changed. |
BackgroundBrush | Brush | Gets the background brush. | |
CheckBoxVisibility | Visibility | Gets or sets the check box visibility. | |
Children | ObservableCollection<LayerListItem> | Gets the children. | |
ChildrenContainerVisibility | Visibility | Gets or sets the children container visibility. | |
ConcreteObject | Object | Gets or sets the concrete object. | |
ContextMenuItems | Collection<MenuItem> | Gets the context menu items. | |
DoubleClicked | Action | Gets or sets the double clicked. | |
ExpandButtonVisibility | Visibility | Gets or sets the expand button visibility. | |
FontBrush | Brush | Gets or sets the font brush. | |
FontStyle | FontStyle | Gets or sets the font style. | |
FontWeight | FontWeight | Gets or sets the font weight. | |
HighlightBackgroundBrush | Brush | Gets or sets the highlight background brush. | |
IsChecked | Boolean | Gets or sets a value indicating whether this instance is checked. | |
IsExpanded | Boolean | Gets or sets a value indicating whether this instance is expanded. | |
IsRenaming | Boolean | Gets or sets a value indicating whether this instance is renaming. | |
IsSelected | Boolean | Gets or sets a value indicating whether this instance is selected. | |
LowerLineVisibility | Visibility | Gets or sets the lower line visibility. | |
Name | String | Gets or sets the name. | |
Parent | LayerListItem | Gets or sets the parent. | |
PreviewImage | Image | Gets or sets the preview image. | |
SideImage | Image | Gets or sets the side image. | |
UpperLineVisibility | Visibility | Gets or sets the upper line visibility. | |
WarningImage | Image | Gets or sets the warning image. | |
WarningImageVisibility | Visibility | Gets or sets the warning image visibility. |
NameCore | String | Gets or sets the name core. |
PropertyChanged | PropertyChangedEventArgs | Occurs when changed. |
| concreteObject | Object<!– System.Object –> | The concrete object. |
| propertyName | String<!– System.String –> | Name of the property. |
<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –> Go Back
| Brush<!– System.Windows.Media.Brush –> |
| Visibility<!– System.Windows.Visibility –> |
Gets the children.
| ObservableCollection<LayerListItem><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.LayerListItem} –> |
| Collection<MenuItem><!– System.Collections.ObjectModel.Collection{System.Windows.Controls.MenuItem} –> |
| Action<!– System.Action –> |
| FontStyle<!– System.Windows.FontStyle –> |
| FontWeight<!– System.Windows.FontWeight –> |
| LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –> |
| Image<!– System.Windows.Controls.Image –> |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
