<!– Class –> This class represents a list item for a style layer
*System.Object ThinkGeo.MapSuite.GisEditor.LayerListItem *ThinkGeo.MapSuite.GisEditor.StyleLayerListItem
StyleLayerListItem | Object | Initializes a new instance of the class. |
CanContainStyleItem | StyleLayerListItem | Determines whether this instance contain style item the specified style item. | |
CloneDeep | Clones the deep. | ||
GetPreviewImage | Int32, Int32 | Gets the preview image. | |
GetRestrictStyleCategories | Gets the restrict style categories. | ||
GetUI | StyleBuilderArguments | Gets the UI. | |
ToString | Object | ||
UpdateConcreteObject | Updates the concrete object. | ||
UpdateStyleItem | Updates the style item. | ||
UpdateUI | StyleUserControl | Updates the UI. |
CanContainStyleItemCore | StyleLayerListItem | Determines whether this instance contain style item core the specified style item. | |
CloneDeepCore | Clones the deep core. | ||
GetPreviewImageCore | Int32, Int32 | Gets the preview image core. | |
GetRestrictStyleCategoriesCore | Gets the restrict style categories core. | ||
GetUICore | StyleBuilderArguments | Gets the UI core. | |
MemberwiseClone | Object | ||
OnConcreteObjectUpdated | Called when object updated. | ||
OnPropertyChanged | String | LayerListItem | Called when changed. |
UpdateConcreteObjectCore | Updates the concrete object core. | ||
UpdateStyleItemCore | Updates the style item core. | ||
UpdateUICore | UserControl | Updates the UI core. |
BackgroundBrush | Brush | LayerListItem | Gets the background brush. |
CanAddInnerStyle | Boolean | Gets or sets a value indicating whether this instance can add inner style. | |
CanRename | Boolean | Gets or sets a value indicating whether this instance can rename. | |
CheckBoxVisibility | Visibility | LayerListItem | Gets or sets the check box visibility. |
Children | ObservableCollection<LayerListItem> | LayerListItem | Gets the children. |
ChildrenContainerVisibility | Visibility | LayerListItem | Gets or sets the children container visibility. |
ConcreteObject | Object | LayerListItem | Gets or sets the concrete object. |
ContextMenuItems | Collection<MenuItem> | LayerListItem | Gets the context menu items. |
DoubleClicked | Action | LayerListItem | Gets or sets the double clicked. |
ExpandButtonVisibility | Visibility | LayerListItem | Gets or sets the expand button visibility. |
FontBrush | Brush | LayerListItem | Gets or sets the font brush. |
FontStyle | FontStyle | LayerListItem | Gets or sets the font style. |
FontWeight | FontWeight | LayerListItem | Gets or sets the font weight. |
HighlightBackgroundBrush | Brush | LayerListItem | Gets or sets the highlight background brush. |
IsChecked | Boolean | LayerListItem | Gets or sets a value indicating whether this instance is checked. |
IsExpanded | Boolean | LayerListItem | Gets or sets a value indicating whether this instance is expanded. |
IsRenaming | Boolean | LayerListItem | Gets or sets a value indicating whether this instance is renaming. |
IsSelected | Boolean | LayerListItem | Gets or sets a value indicating whether this instance is selected. |
LowerLineVisibility | Visibility | LayerListItem | Gets or sets the lower line visibility. |
Name | String | LayerListItem | Gets or sets the name. |
Parent | LayerListItem | LayerListItem | Gets or sets the parent. |
PreviewImage | Image | LayerListItem | Gets or sets the preview image. |
SideImage | Image | LayerListItem | Gets or sets the side image. |
UpperLineVisibility | Visibility | LayerListItem | Gets or sets the upper line visibility. |
WarningImage | Image | LayerListItem | Gets or sets the warning image. |
WarningImageVisibility | Visibility | LayerListItem | Gets or sets the warning image visibility. |
ZoomLevelRange | String | Gets or sets the zoom level range. |
NameCore | String | LayerListItem(overriden) | Gets or sets the name core. |
ConcreteObjectUpdated | EventArgs | Occurs when object updated. | |
PropertyChanged | PropertyChangedEventArgs | LayerListItem | Occurs when changed. |
| concreteObject | Object<!– System.Object –> | The concrete object. |
| Boolean<!– System.Boolean –> | true if this instance contain style item the specified style item; otherwise, false. |
| styleItem | StyleLayerListItem<!– ThinkGeo.MapSuite.GisEditor.StyleLayerListItem –> | The style item. |
<!– ThinkGeo.MapSuite.GisEditor.StyleLayerListItem –> Go Back
Clones the deep.
| StyleLayerListItem<!– ThinkGeo.MapSuite.GisEditor.StyleLayerListItem –> | clone deep style layer list item object |
| Byte[]<!– System.Bytethinkgeo.mapsuite.giseditor.stylelayerlistitem –> | The previewImage buffer bytes arry |
| screenWidth | Int32<!– System.Int32 –> | Width of the screen. |
| screenHeight | Int32<!– System.Int32 –> | Height of the screen. |
| StyleCategories<!– ThinkGeo.MapSuite.GisEditor.StyleCategories –> | The style categories |
Gets the UI.
| StyleUserControl<!– ThinkGeo.MapSuite.GisEditor.StyleUserControl –> | The style user control |
| styleArguments | StyleBuilderArguments<!– ThinkGeo.MapSuite.GisEditor.StyleBuilderArguments –> | The style arguments. |
Updates the UI.
| styleItemUI | StyleUserControl<!– ThinkGeo.MapSuite.GisEditor.StyleUserControl –> | The style item UI. |
| Boolean<!– System.Boolean –> | true if this instance contain style item core the specified style item; otherwise, false. |
Gets the UI core.
| propertyName | String<!– System.String –> | Name of the property. |
<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –> Go Back
| styleItemUI | UserControl<!– System.Windows.Controls.UserControl –> | The style item UI. |
| Brush<!– System.Windows.Media.Brush –> |
| Visibility<!– System.Windows.Visibility –> |
Gets the children.
| ObservableCollection<LayerListItem><!– System.Collections.ObjectModel.ObservableCollection{ThinkGeo.MapSuite.GisEditor.LayerListItem} –> |
| Collection<MenuItem><!– System.Collections.ObjectModel.Collection{System.Windows.Controls.MenuItem} –> |
| Action<!– System.Action –> |
| FontStyle<!– System.Windows.FontStyle –> |
| FontWeight<!– System.Windows.FontWeight –> |
| LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –> |
| Image<!– System.Windows.Controls.Image –> |
<!– ThinkGeo.MapSuite.GisEditor.LayerListItem(overriden) –> Go Back
| Event Arguments |
| EventArgs<!– System.EventArgs –> |
| Event Arguments |
| PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
