thinkgeo.mapsuite.giseditor.storablesettings
ThinkGeo.MapSuite.GisEditor.StorableSettings
<!– Class –> This class represents storable settings
Public MethodStorableSettings Initializes a new instance of the class.
Public MethodStorableSettings Dictionary<String, String>, Dictionary<String, String> Initializes a new instance of the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyGlobalSettings Dictionary<String,String> Gets the global settings.
Public PropertyProjectSettings Dictionary<String,String> Gets the project settings.
StorableSettings()
Name Type Description
Go Back
StorableSettings(Dictionary<String, String>, Dictionary<String, String>)
globalSettings Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> The global settings.
projectSettings Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> The project settings.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
GlobalSettings
Return Type
<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Go Back
ProjectSettings
Return Type
thinkgeo.mapsuite.giseditor.storablesettings.txt · Last modified: 2017/03/16 21:59 (external edit)
