thinkgeo.mapsuite.giseditor.layerplugin
ThinkGeo.MapSuite.GisEditor.LayerPlugin
<!– Class –> This class is the base class of all LayerPlugins. This plugin provides the functionality of creating a specific type of layer instance.
Protected MethodLayerPlugin Initializes a new instance of the class.
Public MethodApplySettings StorableSettings Plugin Applies the settings to this plugin.
Public MethodGetLayerListItem Layer This method gets a hierarchy object to build the layer list tree.
Public MethodGetLayerType Gets the type of the layer. GisEditor will use this method to find a match plugin to create a specific layer instance.
Public MethodGetLayers This method creates layers instance. In this method, it might popup a dialog to configuration. For example, a ShapeFileFeatureLayer is based on a shapefile, we need popup an OpenFileDialog to choose a file. Or MSSql layer needs a connection string to connect to the server, etc.
Public MethodGetLayers GetLayersParameters
Public MethodGetPropertiesUI Layer Gets an UI that holds information of the pass layer.
Public MethodGetSettings Plugin Gets plugin settings to save.
Public MethodGetSettingsUI Plugin Gets an UI that configures settings.
Public MethodGetType Object
Public MethodGetUri Layer Gets the name of passed layer
Public MethodLoad Plugin This method raises when load this plugin.
Public MethodToString Object
Public MethodUnload Plugin This method raises when unload this plugin.
Protected MethodApplySettingsCore StorableSettings Plugin Applies the settings to this plugin.
Protected MethodGetLayerListItemCore Layer This method gets a hierarchy object to build the layer list tree.
Protected MethodGetLayerTypeCore Gets the type of the layer. GisEditor will use this method to find a match plugin to create a specific layer instance. This is the core method of public Type GetLayerType() for override.
Protected MethodGetLayersCore GetLayersParameters This method creates layers instance. In this method, it might popup a dialog to configuration. For example, a ShapeFileFeatureLayer is based on a shapefile, we need popup an OpenFileDialog to choose a file. Or MSSql layer needs a connection string to connect to the server, etc.
Protected MethodGetPropertiesUICore Layer Gets an UI that holds information of the pass layer.
Protected MethodGetSettingsCore Plugin Gets plugin settings to save.
Protected MethodGetSettingsUICore Plugin Gets an UI that configures settings.
Protected MethodGetUriCore Layer Gets the name of passed layer
Protected MethodLoadCore Plugin This method raises when load this plugin.
Protected MethodOnGettingLayers GettingLayersLayerPluginEventArgs
Protected MethodOnGottenLayers GottenLayersLayerPluginEventArgs
Protected MethodUnloadCore Plugin This method raises when unload this plugin.
Public PropertyAuthor String Plugin Gets or sets author information for plugin.
Public PropertyDescription String Plugin Gets or sets description for plugin.
Public PropertyExtensionFilter String Gets or sets the extension filter that allows to create a specific layer.
Public PropertyId String Plugin Gets the identify of plugin.
Public PropertyIndex Int32 Plugin Gets or sets the index of the plugin.
Public PropertyIsActive Boolean Plugin Gets or sets a value indicating whether this plugin is active.
Public PropertyIsRequired Boolean Plugin Gets or sets a value indicating whether this plugin is required.
Public PropertyLargeIcon ImageSource Plugin Gets or sets large icon for plugin.
Public PropertyName String Plugin Gets or sets the name of plugin.
Public PropertySmallIcon ImageSource Plugin Gets or sets small icon path for plugin.
LayerPlugin()
Name Type Description
Go Back
ApplySettings(StorableSettings)
Return Type Description
Void<!– System.Void –>
settings StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> The settings to be applied to this plugin.
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetLayerListItem(Layer)
LayerListItem<!– ThinkGeo.MapSuite.GisEditor.LayerListItem –>
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer list item to build the layer list tree.
<!– ThinkGeo.MapSuite.GisEditor.LayerPlugin –> Go Back
GetLayerType()
Type<!– System.Type –> A type of subclasses that inherit from ThinkGeo.MapSuite.Layer.
GetLayers()
Collection<Layer><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Layer} –> A set of specific layers that created by this plugin.
GetLayers(GetLayersParameters)
getLayersParameters GetLayersParameters<!– ThinkGeo.MapSuite.GisEditor.GetLayersParameters –>
GetPropertiesUI(Layer)
UserControl<!– System.Windows.Controls.UserControl –> An UI that holds information of the pass layer
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer that to build the UI.
GetSettings()
StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> Plugin's settings to save.
GetSettingsUI()
SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> A SettingUserControl that configures settings.
GetUri(Layer)
Uri<!– System.Uri –> The path file name of this layer.
layer Layer<!– ThinkGeo.MapSuite.Core.Layer –> The layer to get path file name.
Load()
String<!– System.String –>
Unload()
ApplySettingsCore(StorableSettings)
GetLayerListItemCore(Layer)
GetLayerTypeCore()
GetLayersCore(GetLayersParameters)
GetPropertiesUICore(Layer)
GetSettingsCore()
GetSettingsUICore()
GetUriCore(Layer)
LoadCore()
OnGettingLayers(GettingLayersLayerPluginEventArgs)
e GettingLayersLayerPluginEventArgs<!– ThinkGeo.MapSuite.GisEditor.GettingLayersLayerPluginEventArgs –>
OnGottenLayers(GottenLayersLayerPluginEventArgs)
e GottenLayersLayerPluginEventArgs<!– ThinkGeo.MapSuite.GisEditor.GottenLayersLayerPluginEventArgs –>
UnloadCore()
Author
Return Type
Description
Return Type
ExtensionFilter
Return Type
Id
Return Type
Index
<remarks> Plugins are orded by this property. </remarks>
Return Type
IsActive
Return Type
IsRequired
Return Type
LargeIcon
<remarks> Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource. </remarks>
Return Type
ImageSource<!– System.Windows.Media.ImageSource –>
Return Type
SmallIcon
Return Type
GettingLayers
Event Arguments
Event Arguments
GottenLayers
Event Arguments
Event Arguments
NOTOC GisEditorInfrastructure ThinkGeo.MapSuite.GisEditor UpdateDocumentation
thinkgeo.mapsuite.giseditor.layerplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
