thinkgeo.mapsuite.mvcedition.custompopupsetting
ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting
A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
CustomPopupSetting(CustomPopup)
  • Initializes a new instance of the CustomPopupSetting class.
BackgroundColor(GeoColor)
  • Set backgroundColor for Element property and retun the CustomPopupSetting
  • backgroundColor
    • Type:GeoColor
    • Description:A backgroundColor for Element property
BorderColor(GeoColor)
  • Set borderColor for Element property and retun the CustomPopupSetting
  • borderColor
    • Type:GeoColor
    • Description:A borderColor for Element property
BorderWidth(Int32)
  • Set borderWidth for Element property and retun the CustomPopupSetting
  • borderWidth
    • Description:A borderWidth for Element property
ContentHtml(String)
  • Set contentHtml for Element property and retun the CustomPopupSetting
  • contentHtml
    • Description:A contentHtml for Element property
BackgroundImageVirtualPath(String)
  • Set backgroundImageVirtualPath for Element property and retun the CustomPopupSetting
  • backgroundImageVirtualPath
    • Description:A backgroundImageVirtualPath for Element property
Position(PointShape)
Width(Int32)
  • width
Height(Int32)
  • height
IsVisible(Boolean)
  • isVisible
Opacity(Single)
  • opacity
    • Type:Single
AutoSize(Boolean)
  • autoSize
AutoPan(Boolean)
  • autoPan
HasCloseButton(Boolean)
  • hasCloseButton
OffsetXInPixels(Int32)
  • offsetXInPixels
OffsetYInPixels(Int32)
  • offsetYInPixels
Element
thinkgeo.mapsuite.mvcedition.custompopupsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
