thinkgeo.mapsuite.mvcedition.custompopup
ThinkGeo.MapSuite.MvcEdition.CustomPopup
Represents a pop up window whose style and background can be customized.
    • ThinkGeo.MapSuite.MvcEdition.Popup
      • ThinkGeo.MapSuite.MvcEdition.CustomPopup
CustomPopup()
  • Initialize an instance of the CustomPopup class.
CustomPopup(String)
  • id
CustomPopup(String,PointShape)
  • id
CustomPopup(String,PointShape,String)
  • id
  • contentHtml
CustomPopup(String,PointShape,String,Int32,Int32)
  • id
  • contentHtml
  • width
  • height
CustomPopup(String,PointShape,String,Int32,Int32,Boolean)
  • id
  • contentHtml
  • width
  • height
  • autoPan
CustomPopup(String,PointShape,String,Int32,Int32,Boolean,Boolean)
  • id
  • contentHtml
  • width
  • height
  • autoPan
  • hasCloseButton
CustomPopup(String,PointShape,String,Int32,Int32,Boolean,Boolean,Int32)
  • id
  • contentHtml
  • width
  • height
  • autoPan
  • hasCloseButton
  • borderWidth
CloneShallow()
  • Type:Popup
ToJson()
FromJson(String)
  • jsonString
BackgroundColor
Gets or sets the color applied to the background of the popup object.
BorderColor
Gets or sets the color applied to the border of the popup object.
BorderWidth
Gets or sets the width of the popup's border.
ContentHtml
Gets or sets the content HTML of the popup window.
BackgroundImageVirtualPath
Gets or sets the virtual path of the background image. You can set any image as the popup's background.
Id
Position
Width
Height
IsVisible
Opacity
  • Type:Single
AutoSize
AutoPan
HasCloseButton
OffsetXInPixels
OffsetYInPixels
PopupType
Gets a string that represents the type of the Popup object.
thinkgeo.mapsuite.mvcedition.custompopup.txt · Last modified: 2017/03/16 21:59 (external edit)
