This class represents a canvas that is used to draw geographic shapes with GDI+.
 GetStreamFromGeoImage(GeoImage)
 DrawWorldImageWithoutScaling(Bitmap,Double,Double,DrawingLevel)
 DrawWorldImageWithoutScaling(Bitmap,Double,Double,DrawingLevel,Single,Single,Single)
 DrawScreenImageWithoutScaling(Bitmap,Single,Single,DrawingLevel,Single,Single,Single)
 DrawArea(AreaBaseShape,GeoPen,DrawingLevel)
 DrawArea(Feature,GeoBrush,DrawingLevel)
 DrawArea(AreaBaseShape,GeoBrush,DrawingLevel)
 DrawArea(Feature,GeoPen,GeoBrush,DrawingLevel)
 DrawArea(AreaBaseShape,GeoPen,GeoBrush,DrawingLevel)
 DrawArea(Feature,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawArea(AreaBaseShape,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawArea(IEnumerable<ScreenPointF[]>,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawLine(Feature,GeoPen,DrawingLevel)
 DrawLine(LineBaseShape,GeoPen,DrawingLevel)
 DrawLine(Feature,GeoPen,DrawingLevel,Single,Single)
 DrawLine(LineBaseShape,GeoPen,DrawingLevel,Single,Single)
 DrawLine(IEnumerable<ScreenPointF>,GeoPen,DrawingLevel,Single,Single)
 DrawEllipse(Feature,Single,Single,GeoPen,DrawingLevel)
 DrawEllipse(PointBaseShape,Single,Single,GeoPen,DrawingLevel)
 DrawEllipse(Feature,Single,Single,GeoBrush,DrawingLevel)
 DrawEllipse(PointBaseShape,Single,Single,GeoBrush,DrawingLevel)
 DrawEllipse(Feature,Single,Single,GeoPen,GeoBrush,DrawingLevel)
 DrawEllipse(PointBaseShape,Single,Single,GeoPen,GeoBrush,DrawingLevel)
 DrawEllipse(Feature,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawEllipse(PointBaseShape,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawEllipse(ScreenPointF,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawWorldImageWithoutScaling(GeoImage,Double,Double,DrawingLevel)
 DrawWorldImageWithoutScaling(GeoImage,Double,Double,DrawingLevel,Single,Single,Single)
 DrawScreenImageWithoutScaling(GeoImage,Single,Single,DrawingLevel,Single,Single,Single)
 DrawWorldImage(GeoImage,Double,Double,Single,Single,DrawingLevel)
 DrawWorldImage(GeoImage,Double,Double,Double,DrawingLevel,Single,Single,Single)
 DrawWorldImage(GeoImage,Double,Double,Single,Single,DrawingLevel,Single,Single,Single)
 DrawScreenImage(GeoImage,Single,Single,Single,Single,DrawingLevel,Single,Single,Single)
 DrawTextWithScreenCoordinate(String,GeoFont,GeoBrush,Single,Single,DrawingLevel)
 DrawTextWithScreenCoordinate(String,GeoFont,GeoBrush,GeoPen,Single,Single,DrawingLevel)
 DrawTextWithWorldCoordinate(String,GeoFont,GeoBrush,Double,Double,DrawingLevel)
 DrawTextWithWorldCoordinate(String,GeoFont,GeoBrush,GeoPen,Double,Double,DrawingLevel)
 DrawText(String,GeoFont,GeoBrush,IEnumerable<ScreenPointF>,DrawingLevel)
 DrawText(String,GeoFont,GeoBrush,GeoPen,IEnumerable<ScreenPointF>,DrawingLevel,Single,Single,Single)
 BeginDrawing(Object,RectangleShape,GeographyUnit)
 FillBackground(GeoImage,GeoBrush)
 ConvertGeoImageToMemoryStream(GeoImage)
 ConvertGeoImageToMemoryStream(GeoImage,ImageFormat)
 DrawAreaCore(IEnumerable<ScreenPointF[]>,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawLineCore(IEnumerable<ScreenPointF>,GeoPen,DrawingLevel,Single,Single)
 DrawEllipseCore(ScreenPointF,Single,Single,GeoPen,GeoBrush,DrawingLevel,Single,Single,PenBrushDrawingOrder)
 DrawScreenImageWithoutScalingCore(GeoImage,Single,Single,DrawingLevel,Single,Single,Single)
 DrawScreenImageCore(GeoImage,Single,Single,Single,Single,DrawingLevel,Single,Single,Single)
 DrawTextCore(String,GeoFont,GeoBrush,GeoPen,IEnumerable<ScreenPointF>,DrawingLevel,Single,Single,Single)
 MeasureTextCore(String,GeoFont)
 BeginDrawingCore(Object,RectangleShape,GeographyUnit)
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: Compositing is done during rendering when the source pixels are combined with the destination pixels to produce the resultant pixels. The quality of compositing directly relates to the visual quality of the output and is inversely proportional to the render time. The higher the quality, the slower the render time. This is because the higher the quality level, the more surrounding pixels need to be taken into account during the composite. The linear quality setting (AssumeLinear) compromises by providing better quality than the default quality at a slightly lower speed.
This property returns or sets the rendering quality for this GeoCanvas.
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: The smoothing mode specifies whether lines, curves, and the edges of filled areas use smoothing (also called antialiasing). One exception is that path gradient brushes do not obey the smoothing mode. Areas filled using a PathGradientBrush are rendered the same way (aliased) regardless of the SmoothingMode property.
This property indicates whether a GdiPlusGeoCanvas has the KeyColor or not. If it has no KeyColor, it will throw an exception when you get or set the value of KeyColors property.
The default value is true.
This property returns or sets the rendering mode for text associated with this GeoCanvas.
This property is used for GDI+ drawing. The excerpt below is from the GDI+ documentation: The text rendering hint specifies whether text renders with antialiasing.
Gets or sets the interpolation mode associated with this System.Drawing.Graphics.
