 Feature(BaseShape,IDictionary<String,String>)
 Feature(BaseShape,IEnumerable<String>)
 Feature(String,String,IDictionary<String,String>)
 Feature(String,String,IEnumerable<String>)
 Feature(Byte[],String,IEnumerable<String>)
 Feature(Byte[],String,IDictionary<String,String>)
 Feature(Vertex,String,IEnumerable<String>)
 Feature(Vertex,String,IDictionary<String,String>)
 Feature(Double,Double,String,IEnumerable<String>)
 Feature(Double,Double,String,IDictionary<String,String>)
 CloneDeep(IEnumerable<String>)
 CloneDeep(ReturningColumnsType)
The Id is a string that represents the unique identifier for this Feature. If the feature is returned from a FeatureSource, the Id will be the unique field descriptor used by the FeatureSource. For Shape Files this may be an integer, but for spatial databases the Id may be a GUID.
This property gets a dictionary of values to represent the column data related to this Feature.
This property holds the column data related to this Feature. You can find the values in the dictionary using the column name as the key. Most methods that query and return InternalFeatures allow you to specify which columns of data you want returned with the results. You can also freely add and modify the data, as it is simply an in-memory dictionary. Any values added, deleted or updated will have no effect unless the Feature is part of a transaction.
