thinkgeo.mapsuite.core.buffercaptype
ThinkGeo.MapSuite.Core.BufferCapType
Buffered shapes can be computed with different line-end buffer cap styles. The buffer cap style determines how the line-work for the buffer polygon is constructed at the ends of lines.
Items
Round
  • Summary:End caps are rounded at the line ends.
Square
  • Summary:End caps are truncated flat at the line ends.
Butt
  • Summary:End caps are squared off at the buffer distance beyond the line ends.
thinkgeo.mapsuite.core.buffercaptype.txt · Last modified: 2017/03/16 21:59 (external edit)
