thinkgeo.mapsuite.desktopedition.currentscalechangedwpfmapeventargs
ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs
Provides data for the CurrentScaleChanged event.
      • ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs
CurrentScaleChangedWpfMapEventArgs()
  • Initialize an instance of the CurrentScaleChangedEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28.29
CurrentScaleChangedWpfMapEventArgs(RectangleShape,Double,GeographyUnit,Single,Single)
  • Initialize an instance of the CurrentScaleChangedEventArgs class by passing the currentScale, mapUnit and mapWidth.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28RectangleShape.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.29
  • currentScale
  • mapWidth
    • Type:Single
  • mapHeight
    • Type:Single
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.CurrentScaleChangedWpfMapEventArgs#MemberwiseClone.28.29
CurrentScale
  • This property specifies the CurrentScale of the CurrentScaleChangedEventArgs.
MapUnit
  • This property specifies the MapUnit of the CurrentScaleChangedEventArgs.
  • Type:Single
MapHeight
  • This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
thinkgeo.mapsuite.desktopedition.currentscalechangedwpfmapeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
