thinkgeo.mapsuite.core.vertex
ThinkGeo.MapSuite.Core.Vertex
    • System.ValueType
      • ThinkGeo.MapSuite.Core.Vertex
Vertex(Double,Double)
  • This is the constructor used to create a vertex.
  • None
  • x
    • Description:This parameter represents the horizontal value.
  • y
    • Description:This parameter represents the vertical value.
Vertex(PointShape)
  • None
  • point
    • Description:This parameter is the PointShape you want to convert to a Vertex.
  • This method is an override of the ToString functionality.
  • None
  • This method is an override of the GetHashCode functionality.
  • None
  • This method is an override of the Equals functionality.
  • None
Add(Vertex)
  • This method adds the target vertex to the current vertex.
  • None
  • targetVertex
    • Type:Vertex
    • Description:This parameter represents the vertex you wish to add to the current vertex.
FindMiddleVertexBetweenTwoVertices(Vertex,Vertex)
  • This method returns the middle Vertex of a straight line which two vertices are passing in.
  • Type:Vertex
  • Description:This method returns the middle Vertex between the vertices which passing in.
  • vertex1
    • Type:Vertex
    • Description:start vertex of a straight line
  • vertex2
    • Type:Vertex
    • Description:en vertex of a straight line
  • xOffset
  • yOffset
  • distance
  • angleInDegrees
Rotate(Vertex,Single)
  • vertex
  • degreeAngle
    • Type:Single
Rotate(PointShape,Single)
  • degreeAngle
    • Type:Single
GetDistanceTo(Vertex,GeographyUnit,DistanceUnit)
  • targetVertex
GetDistanceFromVertex(Double,Double)
  • toX
  • toY
X
This property returns the horizontal value of the vertex.
Y
This property returns the vertical value of the vertex.
thinkgeo.mapsuite.core.vertex.txt · Last modified: 2017/03/16 21:59 (external edit)
