thinkgeo.mapsuite.core.linkcolumnvalue
ThinkGeo.MapSuite.Core.LinkColumnValue
    • System.ValueType
      • ThinkGeo.MapSuite.Core.LinkColumnValue
LinkColumnValue(Object)
  • value
LinkColumnValue(Object,String)
  • value
  • level
  • This method is an override of the GetHashCode functionality.
  • None
  • This method is an override of the Equals functionality.
  • None
Level
Value
thinkgeo.mapsuite.core.linkcolumnvalue.txt · Last modified: 2017/03/16 21:59 (external edit)
