Serves as the base class that defines the methods and properties common to all types of popups.
Popup(String,PointShape,Int32,Int32)
Popup(String,PointShape,Int32,Int32,Boolean)
Popup(String,PointShape,Int32,Int32,Boolean,Boolean)
Gets or sets a point shape in world coordinates that represents the position of the popup.
The Opacity property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
Gets or sets a value that indicates whether the popup is automatically resized to fit its contents.
Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed.
Gets or sets a value that indicates whether the popup window has a close button in the upper right corner.
