thinkgeo.mapsuite.mvcedition.mvcclientscriptmanager
ThinkGeo.MapSuite.MvcEdition.MvcClientScriptManager
This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
    • ThinkGeo.MapSuite.MvcEdition.MvcClientScriptManager
MvcClientScriptManager(TextWriter)
  • Initalizes a new instance of the MvcClientScriptManager with the specified TextWriter.
  • textWriter
    • Type:TextWriter
    • Description:The textWriter of the viewContext in the page.
RegisterClientScriptBlock(String,String)
  • Registers a specified client JavaScript block to the page.
  • key
    • Description:A unique identifier for the script file.
  • script
    • Description:The client JavaScript block.
RegisterClientScriptBlock(String,String,Boolean)
  • key
  • script
  • addScriptTag
    • Description:ture to enclose the script block with and tags; otherwise false.
RegisterClientScriptInclude(String,String)
  • Registers a client JavaScript file to the page which contains the control.
  • key
  • url
    • Description:The URL of the script file.
TextWriter
Gets the textwriter of the ViewContext in the page.
  • Type:TextWriter
thinkgeo.mapsuite.mvcedition.mvcclientscriptmanager.txt · Last modified: 2017/03/16 21:59 (external edit)
