thinkgeo.mapsuite.mvcedition.cloudpopup
ThinkGeo.MapSuite.MvcEdition.CloudPopup
Represents the popups that appear in a cloud (a.k.a. balloon) shape.
    • ThinkGeo.MapSuite.MvcEdition.Popup
      • ThinkGeo.MapSuite.MvcEdition.CloudPopup
CloudPopup()
  • Initialize an instance of the CloudPopup class.
CloudPopup(String)
  • Initialize an instance of the CloudPopup class with an Id string.
  • id
    • Description:The identifier by which you can find the popup.
CloudPopup(String,PointShape)
  • Initialize an instance of the CloudPopup class with an Id string and the position.
  • id
  • position
    • Description:A point shape in world coordinates that indicates the position of the popup.
CloudPopup(String,PointShape,String)
  • Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup.
  • id
  • position
  • contentHtml
    • Description:An HTML string rendered as the popup content.
CloudPopup(String,PointShape,String,Int32,Int32)
  • Initialize an instance of the CloudPopup class with Id string, position, popup content and size.
  • id
  • position
  • contentHtml
  • width
    • Description:An int value that indicates the popup's width.
  • height
    • Description:An int value that indicates the popup's height.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean)
  • Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
    • Description:A boolean value indicating whether to pan the map if necessary to show the full popup.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean,Boolean)
  • Initialize an instance of the CloudPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
  • hasCloseButton
    • Description:A boolean value indicating whether the popup should have a close button.
CloneShallow()
  • Type:Popup
ToJson()
FromJson(String)
  • jsonString
ContentHtml
Gets or sets the content HTML of the popup window.
Id
Position
Width
Height
IsVisible
Opacity
  • Type:Single
AutoSize
AutoPan
HasCloseButton
OffsetXInPixels
OffsetYInPixels
PopupType
Gets a string that represents the type of the Popup object.
thinkgeo.mapsuite.mvcedition.cloudpopup.txt · Last modified: 2017/03/16 21:59 (external edit)
