thinkgeo.mapsuite.mvcedition.keyboardmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting
A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
KeyboardMapToolSetting(KeyboardMapTool)
  • Initializes a new instance of the KeyboardMapToolSetting class.
  • mapTool
    • Description:the map Tool which will be assigned to Element property
PanPixels(Int32)
  • Set panPixels for Element property and retun the KeyboardMapToolSetting
  • panPixels
    • Description:A panPixels for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.keyboardmaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
