thinkgeo.mapsuite.mvcedition.featuresourcemarkeroverlaysetting
ThinkGeo.MapSuite.MvcEdition.FeatureSourceMarkerOverlaySetting
A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
FeatureSourceMarkerOverlaySetting(FeatureSourceMarkerOverlay)
  • Initializes a new instance of the FeatureSourceMarkerOverlaySetting class.
FeatureSource(FeatureSource)
  • Set featureSource for Element property and retun the FeatureSourceMarkerOverlaySetting
  • featureSource
    • Description:A featureSource for Element property
SuppressingGridSize(Int32)
  • Set suppressingGridSize for Element property and retun the FeatureSourceMarkerOverlaySetting
  • suppressingGridSize
    • Description:A suppressingGridSize for Element property
ZoomLevelSet(MarkerZoomLevelSet)
  • Set zoomLevelSet for Element property and retun the FeatureSourceMarkerOverlaySetting
OnClientClick(String)
  • clientEventHandler
OnClientMarkersRequested(String)
OnClientMarkersRequesting(String)
DataBindTo(String,String)
  • controllerName
  • actionName
ActionTriggers(Action<Collection<ActionTrigger»)
  • triggerActions
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.featuresourcemarkeroverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
