thinkgeo.mapsuite.mvcedition.featuresourcemarkeroverlay
ThinkGeo.MapSuite.MvcEdition.FeatureSourceMarkerOverlay
Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.MarkerOverlay
        • ThinkGeo.MapSuite.MvcEdition.FeatureSourceMarkerOverlay
FeatureSourceMarkerOverlay()
  • Initialize an instance of the FeatureMarkerOverlay class.
FeatureSourceMarkerOverlay(String)
  • id
    • Description:The identifier string used for retrieving the overlay.
FeatureSourceMarkerOverlay(String,FeatureSource)
  • id
  • featureSource
    • Description:The feature source object that provides the features from which the markers are created.
DataBindTo(String,String)
  • controllerName
  • actionName
GetMarkers(RectangleShape,Int32)
  • Type:Collection<Marker>
  • currentZoomLevelId
ToJson()
FromJson(String)
  • jsonString
GetMarkersCore(RectangleShape,Int32)
  • Returns a collection of markers based on the extent and zoomlevel that you passed in.
  • Description:A collection of marker objects that will be serialized to the client.
  • worldExtent
    • Description:The extent that includes the markers you want to serialize.
    • Description:An int value that indicates which zoomlevel the map is currently at.
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
FeatureSource
Gets or sets a feature source object that provides the features from which the markers are created.
ZoomLevelSet
Gets the ZoomLevelSet object that controls the markers' generation.
SuppressingGridSize
Gets or sets the grid size in screen coordinate to suppress markers in current Viewport.
Current ViewPort will be split into several cells by FilterGridSize, one cell will contains only one marker in it, in another word, markers which are near too close will be removed. if the value is greater than 0, this function will be enabled.
IsBaseOverlay
OnClientClick
OnClientMarkersRequesting
OnClientMarkersRequested
ActionTriggers
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
Id
OnClientAutoRefreshTick
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
IsDefault
TRU=
ERQ=
thinkgeo.mapsuite.mvcedition.featuresourcemarkeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
