Represents a small icon on the map that is used for marking a point.
Marker(Double,Double,WebImage)
Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays.
Gets or sets a PointShape object that represents the current location of the marker.
Gets or sets a GeoIcon object that determines the appearance of the marker.
Gets or sets a float value between 0 and 1 that indicates the transparency level of the marker.
The Opacity property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
Gets or sets a string that represents the unique identifier for this marker. When you add marker into markers collection, it's also the key to find it back, Marker is a virtual control, and we don't allowed to add the same marker in this collection for many times like normal controls.
