thinkgeo.mapsuite.mvcedition.contextmenu
ThinkGeo.MapSuite.MvcEdition.ContextMenu
This class represents a right-click shortcut menu used in the map control.
    • ThinkGeo.MapSuite.MvcEdition.ContextMenu
ContextMenu()
  • Initializes a new instance of the ContextMenu class with no menu items specified.
ContextMenu(String,Int32)
  • Initializes a new instance of the ContextMenu class with the specified identifier and width.
  • id
    • Description:The key of the context menu in string format.
  • width
    • Description:The width of the context menu.
ContextMenu(String,Int32,String)
  • Initializes a new instance of the ContextMenu class with the identifier, width and CSS class string.
  • id
  • width
  • cssClass
    • Description:The CSS class for the context menu.
CloneDeep()
  • Creates a deep copy of this ContextMenu object.
  • Description:A deep copy of the ContextMenu object.
ToJson()
  • Returns a JSON string that contains information for creating the context menu at the client side.
  • Description:A string for creating the context menu at the client side.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
PBU=(String)
  • fullId
Id
Gets the identifier of the ContextMenu object.
Width
Gets or sets the width of the context menu.
CssClass
Gets or sets the CSS class of the context menu.
MenuItems
Gets the menu item collection of the context menu.
thinkgeo.mapsuite.mvcedition.contextmenu.txt · Last modified: 2017/03/16 21:59 (external edit)
