thinkgeo.mapsuite.mvcedition.singlethreadtileresource
ThinkGeo.MapSuite.MvcEdition.SingleThreadTileResource
This is an asynchronous HTTP handler which is used to handle web map services.
    • ThinkGeo.MapSuite.MvcEdition.SingleThreadTileResource
SingleThreadTileResource()
  • This is the default constructor for the TileResourceSingleThread class.
ProcessRequest(HttpContext)
  • Enables processing of HTTP Web requests by a custom HttpHandler.
  • context
    • Type:HttpContext
    • Description:A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests.
ProcessRequestCore(HttpContext)
  • context
    • Type:HttpContext
IsReusable
Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance.
thinkgeo.mapsuite.mvcedition.singlethreadtileresource.txt · Last modified: 2017/03/16 21:59 (external edit)
