thinkgeo.mapsuite.mvcedition.arcgisserverrestoverlaysetting
ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlaySetting
A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
ArcGISServerRestOverlaySetting(ArcGISServerRestOverlay)
  • Initializes a new instance of the ArcGISServerRestOverlaySetting class.
Parameters(Action<Dictionary<String,String»)
  • parametersAction
    • Type:Action<Dictionary<String,String»
Projection(String)
  • Set projection that will be sent to the ArcGIS REST server to get the images in the specific projection for Element property and retun the ArcGISServerRestOverlaySetting
  • projection
    • Description:A projection for Element property
TileWidth(Int32)
  • Set tileWidth for Element property and retun the ArcGISServerRestOverlaySetting
  • tileWidth
    • Description:A tileWidth for Element property
TileHeight(Int32)
  • Set tileHeight for Element property and retun the ArcGISServerRestOverlaySetting
  • tileHeight
    • Description:A tileHeight for Element property
TransitionEffect(TransitionEffect)
  • Set transitionEffect for Element property and retun the ArcGISServerRestOverlaySetting
  • transitionEffect
TransitionEffectDelayInMilliseconds(Int32)
  • transitionEffectDelayInMilliseconds
TileType(TileType)
  • Set imageUri for Element property and retun the ArcGISServerRestOverlaySetting
  • tileType
ServerUri(Uri)
  • Set serverUri for Element property and retun the ArcGISServerRestOverlaySetting
  • serverUri
    • Type:Uri
    • Description:A serverUri for Element property
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.arcgisserverrestoverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
