thinkgeo.mapsuite.mvcedition.touchmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.TouchMapToolSetting
A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
TouchMapToolSetting(TouchMapTool)
  • Initializes a new instance of the TouchMapToolSetting class.
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.touchmaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
