thinkgeo.mapsuite.wpfdesktopedition.editinteractiveoverlay
ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay
    • ThinkGeo.MapSuite.WpfDesktopEdition.Overlay
      • ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveOverlay
        • ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay
EditInteractiveOverlay()
  • Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#EditInteractiveOverlay.28.29
CalculateAllControlPoints()
  • This method calculates all control points.
  • First, it will clear all control points. Then it will calculate each control points according to their settings.
MouseDown(InteractionArguments)
  • This method will simulate the MouseDown interaction.
  • This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • interactionArguments
MouseMove(InteractionArguments)
  • This method will simulate the MouseMove interaction.
ManipulationStarted(InteractionArguments)
ManipulationDelta(InteractionArguments)
ManipulationCompleted(InteractionArguments)
MouseUp(InteractionArguments)
  • This method will simulate the MouseUp interaction.
MouseClick(InteractionArguments)
  • This method will simulate the MouseClick interaction.
MouseDoubleClick(InteractionArguments)
  • This method will simulate the MouseDoubleClick interaction.
MouseWheel(InteractionArguments)
  • This method will simulate the MouseWheel interaction.
MouseLeave(InteractionArguments)
  • Occurs when the mouse leave the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseLeave.28InteractionArguments.29
MouseEnter(InteractionArguments)
  • Occurs when the mouse enter the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseEnter.28InteractionArguments.29
  • Description:A interactive result for mouse entering the map.
KeyUp(KeyEventInteractionArguments)
  • Occurs when key up on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#KeyUp.28KeyEventInteractionArguments.29
KeyDown(KeyEventInteractionArguments)
  • Occurs when key down on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#KeyDown.28KeyEventInteractionArguments.29
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Refresh.28TimeSpan.29
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Refresh.28RectangleShape.2C_TimeSpan.29
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Initialize(MapArguments)
  • This method initializes overlay object.
  • This is a wrapper method for the virtual method InitializeCore.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
Refresh(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Refresh.28RectangleShape.29
Refresh()
  • This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
  • The difference from Draw() method is that Refresh() method refreshs all the elements while Draw() does not.
Close()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Close.28.29
Open()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Open.28.29
Draw(RectangleShape)
  • This method draws the overlay with the provided extent in world coordinate.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Draw.28RectangleShape.29
  • targetExtent
    • Description:This parameter indicates an extent in world coordinate for drawing the overlay.
Draw(RectangleShape,OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29
  • targetExtent
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
PanTo(RectangleShape)
  • This method pans the overlay to the provided world extent.
  • Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
  • targetExtent
    • Description:This parameter is the target world extent for panning.
GetBoundingBox()
  • This method gets a bounding box of the Overlay.
  • This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:A RectangleShape indicating the bounding box of this overlay
SaveState()
  • This method saves overlay state to a byte array.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#SaveState.28.29
  • Type:Byte[]
  • Description:A byte array indicates current overlay state.
LoadState(Byte[])
  • This method restore the overlay state back from the specified state.
  • state
    • Type:Byte[]
    • Description:This parameter indicates the state for restore the overlay.
Dispose()
  • This method dispose unmanaged resource used in this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Dispose.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#GetType.28.29
MoveVertexCore(Feature,PointShape,PointShape)
  • This is the Core method of MoveVertex which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MoveVertexCore.28Feature.2C_PointShape.2C_PointShape.29
  • Type:Feature
  • Description:Returns a vertex moved feature.
  • sourceFeature
    • Type:Feature
    • Description:This parameter specifies the source feature to be move vertex from.
  • sourceControlPoint
    • Description:This parameter specifes the source control point to move vertex from the feature.
  • targetControlPoint
    • Description:This parameter specifes the target control point to move vertex from the feature.
RemoveVertex(PointShape,Double)
  • This is the method to remove vertex from a feature.
  • This method is the concrete wrapper for the abstract method RemoveVertexCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:True if remove vertex succeed , other wise return false.
  • targetPointShape
    • Description:This parameter specifies the point shape to search the vertex.
  • searchingTolerance
    • Description:This parameter specifes the searching tolerance to search the vetex.
RemoveVertexCore(Feature,Vertex,Double)
  • This is the Core method of RemoveVertex which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#RemoveVertexCore.28Feature.2C_Vertex.2C_Double.29
  • Type:Feature
  • Description:Returns a vertex removed feature.
  • editShapeFeature
    • Type:Feature
    • Description:This parameter specifies the target feature to be remove vertex from.
  • selectedVertex
    • Type:Vertex
    • Description:This parameter specifies the selected vertex to search the vertex.
OnFeatureDragging(FeatureDraggingEditInteractiveOverlayEventArgs)
  • This event will be fired before dragging the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureDragging.28FeatureDraggingEditInteractiveOverlayEventArgs.29
OnFeatureDragged(FeatureDraggedEditInteractiveOverlayEventArgs)
  • This event will be fired after dragging the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureDragged.28FeatureDraggedEditInteractiveOverlayEventArgs.29
OnFeatureResizing(FeatureResizingEditInteractiveOverlayEventArgs)
  • This event will be fired before resizing the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureResizing.28FeatureResizingEditInteractiveOverlayEventArgs.29
OnFeatureResized(FeatureResizedEditInteractiveOverlayEventArgs)
  • This event will be fired after resizing the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureResized.28FeatureResizedEditInteractiveOverlayEventArgs.29
OnFeatureRotating(FeatureRotatingEditInteractiveOverlayEventArgs)
  • This event will be fired before rotating the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureRotating.28FeatureRotatingEditInteractiveOverlayEventArgs.29
OnFeatureRotated(FeatureRotatedEditInteractiveOverlayEventArgs)
  • This event will be fired after rotating the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureRotated.28FeatureRotatedEditInteractiveOverlayEventArgs.29
OnControlPointSelecting(ControlPointSelectingEditInteractiveOverlayEventArgs)
  • This event will be fired before control point selected.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnControlPointSelecting.28ControlPointSelectingEditInteractiveOverlayEventArgs.29
OnControlPointSelected(ControlPointSelectedEditInteractiveOverlayEventArgs)
  • This event will be fired after control point selected.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnControlPointSelected.28ControlPointSelectedEditInteractiveOverlayEventArgs.29
OnVertexAdding(VertexAddingEditInteractiveOverlayEventArgs)
  • This event will be fired before vertex added to the edit feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexAdding.28VertexAddingEditInteractiveOverlayEventArgs.29
OnVertexAdded(VertexAddedEditInteractiveOverlayEventArgs)
  • This event will be fired after vertex added to the edit feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexAdded.28VertexAddedEditInteractiveOverlayEventArgs.29
OnVertexMoving(VertexMovingEditInteractiveOverlayEventArgs)
  • This event will be fired before moving the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexMoving.28VertexMovingEditInteractiveOverlayEventArgs.29
OnVertexMoved(VertexMovedEditInteractiveOverlayEventArgs)
  • This event will be fired after moving the feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexMoved.28VertexMovedEditInteractiveOverlayEventArgs.29
OnVertexRemoving(VertexRemovingEditInteractiveOverlayEventArgs)
  • This event will be fired before vertex removed from the edit feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexRemoving.28VertexRemovingEditInteractiveOverlayEventArgs.29
OnVertexRemoved(VertexRemovedEditInteractiveOverlayEventArgs)
  • This event will be fired after vertex removed from the edit feature.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexRemoved.28VertexRemovedEditInteractiveOverlayEventArgs.29
SaveStateCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#SaveStateCore.28.29
  • Type:Byte[]
LoadStateCore(Byte[])
  • state
    • Type:Byte[]
OnFeatureEditing(FeatureEditingEditInteractiveOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureEditing.28FeatureEditingEditInteractiveOverlayEventArgs.29
OnFeatureEdited(FeatureEditedEditInteractiveOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureEdited.28FeatureEditedEditInteractiveOverlayEventArgs.29
DrawCore(RectangleShape,OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29
DrawTileCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#DrawTileCore.28GeoCanvas.29
SetSelectedControlPoint(PointShape,Double)
  • This protected method is to set the control point.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#SetSelectedControlPoint.28PointShape.2C_Double.29
  • Description:Returns true if control point are found and set correct, other wise, returns false.
  • targetPointShape
    • Description:This parameter is target point shape we determine to edit.
    • Description:This parameter is the searchinig tolerance to seach the control point.
SetSelectedControlPointCore(PointShape,Double)
  • This protected virtual method is the Core method of SetSelectedControlPoint API.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#SetSelectedControlPointCore.28PointShape.2C_Double.29
  • Type:Feature
  • Description:A feature stands for the selected control point.
  • targetPointShape
EndEditing(PointShape)
  • This method End the editing for the interative editing on the feature in the EditShapesLayer. You can override its logic by rewrite its core method.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#EndEditing.28PointShape.29
  • targetPointShape
    • Description:This is the targetPointShape possible be used when overriding.
EndEditingCore(PointShape)
  • This is the core method of EndEditing method. This method End the editing for the interative editing on the feature in the EditShapesLayer.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#EndEditingCore.28PointShape.29
  • targetPointShape
ClearAllControlPoints()
  • This method clears all control points in corresponding layer.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#ClearAllControlPoints.28.29
CalculateDragControlPoints()
  • This method caculates the Drag control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateDragControlPoints.28.29
CalculateDragControlPointsCore(Feature)
  • This is the core API for the CalculateDragControlPoints, you can override this method if you want to change its logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateDragControlPointsCore.28Feature.29
  • Type:IEnumerable<Feature>
  • Description:A collection of features stands for the Drag control points.
  • feature
    • Type:Feature
    • Description:The target feature to caculate the control point.
CalculateRotateControlPoints()
  • This method caculates the Rotate control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateRotateControlPoints.28.29
CalculateRotateControlPointsCore(Feature)
  • This is the core API for the CalculateRotateControlPoints, you can override this method if you want to change its logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateRotateControlPointsCore.28Feature.29
  • Description:A collection of features stands for the Rotate control points.
  • feature
    • Type:Feature
CalculateResizeControlPoints()
  • This method caculates the Resize control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateResizeControlPoints.28.29
CalculateResizeControlPointsCore(Feature)
  • This is the core API for the CalculateResizeControlPoints, you can override this method if you want to change its logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateResizeControlPointsCore.28Feature.29
  • Description:A collection of features stands for the Resize control points.
  • feature
    • Type:Feature
CalculateVertexControlPoints()
  • This method caculates the vertex control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateVertexControlPoints.28.29
CalculateVertexControlPointsCore(Feature)
  • This is the core API for the CalculateVertexControlPoints, you can override this method if you want to change its logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CalculateVertexControlPointsCore.28Feature.29
  • Description:A collection of features stands for the Vertex control points.
  • feature
    • Type:Feature
MouseDownCore(InteractionArguments)
  • This overrides the MouseDown logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseDownCore.28InteractionArguments.29
MouseMoveCore(InteractionArguments)
  • This overrides the MouseMove logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseMoveCore.28InteractionArguments.29
MouseUpCore(InteractionArguments)
  • This overrides the MouseUp logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseUpCore.28InteractionArguments.29
ManipulationStartedCore(InteractionArguments)
ManipulationDeltaCore(InteractionArguments)
ManipulationCompletedCore(InteractionArguments)
MouseClickCore(InteractionArguments)
  • This overrides the MouseClick logic in its base class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseClickCore.28InteractionArguments.29
MouseDoubleClickCore(InteractionArguments)
  • This overrides the MouseDoubleClick logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseDoubleClickCore.28InteractionArguments.29
DragFeature(Feature,PointShape,PointShape)
  • This is the method to Drag a feature.
  • This method is the concrete wrapper for the abstract method DragFeatureCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Type:Feature
  • Description:Returns a dragged feature.
  • sourceFeature
    • Type:Feature
    • Description:This parameter specifies the source feature to be dragged.
    • Description:This parameter specifes the source control point to drag the feature.
    • Description:This parameter specifes the target control point to drag the feature.
DragFeatureCore(Feature,PointShape,PointShape)
  • This is the Core method of DragFeature which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#DragFeatureCore.28Feature.2C_PointShape.2C_PointShape.29
  • Type:Feature
  • sourceFeature
    • Type:Feature
ResizeFeature(Feature,PointShape,PointShape)
  • This is the method to Resize a feature.
  • This method is the concrete wrapper for the abstract method ResizeFeatureCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Type:Feature
  • Description:Returns a resized feature.
  • sourceFeature
    • Type:Feature
    • Description:This parameter specifies the source feature to be resized.
    • Description:This parameter specifes the source control point to resize the feature.
    • Description:This parameter specifes the target control point to resize the feature.
ResizeFeatureCore(Feature,PointShape,PointShape)
  • This is the Core method of ResizeFeature which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#ResizeFeatureCore.28Feature.2C_PointShape.2C_PointShape.29
  • Type:Feature
  • sourceFeature
    • Type:Feature
RotateFeature(Feature,PointShape,PointShape)
  • This is the method to Rotate a feature.
  • This method is the concrete wrapper for the abstract method RotateFeatureCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Type:Feature
  • Description:Returns a rotated feature.
  • sourceFeature
    • Type:Feature
    • Description:This parameter specifies the source feature to be rotated.
    • Description:This parameter specifes the source control point to rotate the feature.
    • Description:This parameter specifes the target control point to rotate the feature.
RotateFeatureCore(Feature,PointShape,PointShape)
  • This is the Core method of RotateFeature which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#RotateFeatureCore.28Feature.2C_PointShape.2C_PointShape.29
  • Type:Feature
  • sourceFeature
    • Type:Feature
AddVertex(PointShape,Double)
  • This is the method to add vertex from a feature.
  • This method is the concrete wrapper for the abstract method AddVertexCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:True if add vertex succeed , other wise return false.
  • targetPointShape
AddVertexCore(Feature,PointShape,Double)
  • This is the Core method of AddVertex which encapsulate the logic.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#AddVertexCore.28Feature.2C_PointShape.2C_Double.29
  • Type:Feature
  • Description:Returns a vertex added feature.
  • targetFeature
    • Type:Feature
    • Description:This parameter specifies the target feature to be add vertex from.
  • targetPointShape
    • Description:This parameter specifies the target vertex to be added.
MoveVertex(Feature,PointShape,PointShape)
  • This is the method to move vertex from a feature.
  • This method is the concrete wrapper for the abstract method MoveVertexCore. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Type:Feature
  • sourceFeature
    • Type:Feature
MouseWheelCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseWheel API.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseWheelCore.28InteractionArguments.29
MouseLeaveCore(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseLeaveCore.28InteractionArguments.29
MouseEnterCore(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MouseEnterCore.28InteractionArguments.29
KeyUpCore(KeyEventInteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#KeyUpCore.28KeyEventInteractionArguments.29
KeyDownCore(KeyEventInteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#KeyDownCore.28KeyEventInteractionArguments.29
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDown is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseDown.28MapMouseDownInteractiveOverlayEventArgs.29
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseMove is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseUp is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseUp.28MapMouseUpInteractiveOverlayEventArgs.29
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDoubleClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseDoubleClick.28MapMouseDoubleClickInteractiveOverlayEventArgs.29
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseWheel is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29
OnMapMouseLeave(MapMouseLeaveInteractiveOverlayEventArgs)
  • Occurs when mouse leave from the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseLeave.28MapMouseLeaveInteractiveOverlayEventArgs.29
OnMapMouseEnter(MapMouseEnterInteractiveOverlayEventArgs)
  • Occurs when mouse enter on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseEnter.28MapMouseEnterInteractiveOverlayEventArgs.29
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
  • Occurs when key up on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
  • Occurs when key down on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapKeyDown.28MapKeyDownInteractiveOverlayEventArgs.29
LhQ=(LayerTile)
IhQ=(RectangleShape,Double)
  • resolution
InitializeCore(MapArguments)
  • When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • mapArguments
RefreshCore(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#RefreshCore.28RectangleShape.29
RefreshCore()
CloseCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CloseCore.28.29
OpenCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OpenCore.28.29
4hM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
PanToCore(RectangleShape)
  • targetExtent
OnDrawing(DrawingOverlayEventArgs)
  • This method raises before the overlay is drawing.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This method raises after the overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29
GetBoundingBoxCore()
  • This method returns the bounding box of the Overlay.
  • Description:This method returns the bounding box of the Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Finalize.28.29
Dispose(Boolean)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Dispose.28Boolean.29
  • disposing
OnRefreshing(OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#MemberwiseClone.28.29
PolygonTrackMode
EditShapesLayer
This property gets the InMemoryFeatureLayer which holds the edit shapes.
EditsInProcessLayer
DragControlPointsLayer
This property gets the InMemoryFeatureLayer which holds the control points for drag.
Every control points for drag are not the existing vertex of the edit shapes.
RotateControlPointsLayer
This property gets the InMemoryFeatureLayer which holds the control points for rotate.
Every control points for rotate are not the existing vertex of the edit shapes.
ResizeControlPointsLayer
This property gets the InMemoryFeatureLayer which holds the control points for resize.
Every control points for resize are not the existing vertex of the edit shapes.
ExistingControlPointsLayer
This property gets the InMemoryFeatureLayer which holds the control points which represents the existing vertices of the edit shapes.
Every control points in this layer are the existing vertices of the edit shapes.
CanDrag
Gets a value which indicates whether the shape can be dragged.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#CanDrag
CanReshape
Gets a value which indicates whether the shape can be reshaped.
CanResize
Gets a value which indicates whether the shape can be resized.
CanRotate
Gets a value which indicates whether the shape can be rotated.
CanAddVertex
Gets a value which indicates whether the shape can Add new vertex.
CanRemoveVertex
Gets a value which indicates whether the shape can remove a existing vertex.
IsEmpty
This property indicates whether this overlay is empty or not.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#IsEmpty
DrawingMarginPercentage
RenderMode
This property gets and sets the render mode for drawing this overlay.
Set GdiPlus to render map image with Gdi+. We recommend use this value with large data. Set DrawingVisual to render map image with DrawingVisual feature in WPF. Use it when the spatial data is small to get better responding.
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name of this overaly.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#Name
MapArguments
Gets or sets current map information which will be used for calculating mechanism.
OverlayCanvas
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
  • Type:Canvas
IsBase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#IsBase
CanRefreshRegion
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets if this overlay is visible.
Attribution
ControlPointType
Gets or sets the ControlPointType for the control points of the edit shapes.
SelectControlPointFeature
This property gets the feature represents the select control points of the edit shapes.
OriginalEditingFeature
This property gets the feature represents the original editing feature.
PreviousExtent
Gets or sets the previous exent of the overlay.
3BM=
IsOverlayInitialized
Gets or sets if the overlay canvas is initialized.
FeatureDragged This event will be fired after drag the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureDragged.28FeatureDraggedEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureDraggedEditInteractiveOverlayEventArgs
FeatureDragging This event will be fired before drag the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureDragging.28FeatureDraggingEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureDraggingEditInteractiveOverlayEventArgs
FeatureResized This event will be fired after resize the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureResized.28FeatureResizedEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureResizedEditInteractiveOverlayEventArgs
FeatureResizing This event will be fired before resize the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureResizing.28FeatureResizingEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureResizingEditInteractiveOverlayEventArgs
FeatureRotated This event will be fired after rotate the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureRotated.28FeatureRotatedEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotating This event will be fired before rotate the feature.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureRotating.28FeatureRotatingEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureRotatingEditInteractiveOverlayEventArgs
VertexAdded This event will be fired after add the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexAdded.28VertexAddedEditInteractiveOverlayEventArgs.29
Event Arguments:VertexAddedEditInteractiveOverlayEventArgs
VertexAdding This event will be fired before add the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexAdding.28VertexAddingEditInteractiveOverlayEventArgs.29
Event Arguments:VertexAddingEditInteractiveOverlayEventArgs
VertexMoved This event will be fired after move the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexMoved.28VertexMovedEditInteractiveOverlayEventArgs.29
Event Arguments:VertexMovedEditInteractiveOverlayEventArgs
VertexMoving This event will be fired before move the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexMoving.28VertexMovingEditInteractiveOverlayEventArgs.29
Event Arguments:VertexMovingEditInteractiveOverlayEventArgs
VertexRemoved This event will be fired after remove the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexRemoved.28VertexRemovedEditInteractiveOverlayEventArgs.29
Event Arguments:VertexRemovedEditInteractiveOverlayEventArgs
VertexRemoving This event will be fired before remove the vertex.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnVertexRemoving.28VertexRemovingEditInteractiveOverlayEventArgs.29
Event Arguments:VertexRemovingEditInteractiveOverlayEventArgs
ControlPointSelected This event will be fired after select the control point.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnControlPointSelected.28ControlPointSelectedEditInteractiveOverlayEventArgs.29
Event Arguments:ControlPointSelectedEditInteractiveOverlayEventArgs
ControlPointSelecting This event will be fired before select the control point.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnFeatureEdited.28FeatureEditedEditInteractiveOverlayEventArgs.29
Event Arguments:FeatureEditedEditInteractiveOverlayEventArgs
MapMouseDown This event will be fired when Mouse pressed Down on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseDown.28MapMouseDownInteractiveOverlayEventArgs.29
Event Arguments:MapMouseDownInteractiveOverlayEventArgs
MapMouseMove This event will be fired when Mouse moved on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp This event will be fired when Mouse released up on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseUp.28MapMouseUpInteractiveOverlayEventArgs.29
Event Arguments:MapMouseUpInteractiveOverlayEventArgs
MapMouseClick This event will be fired when Mouse clicked(mouse up and mouse down in the same postion) on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick This event will be fired when Mouse double clicked on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseDoubleClick.28MapMouseDoubleClickInteractiveOverlayEventArgs.29
Event Arguments:MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseWheel This event will be fired when Mouse wheel on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapMouseLeave Occurs when mouse leave the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseLeave.28MapMouseLeaveInteractiveOverlayEventArgs.29
Event Arguments:MapMouseLeaveInteractiveOverlayEventArgs
MapMouseEnter Occurs when mouse enter the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapMouseEnter.28MapMouseEnterInteractiveOverlayEventArgs.29
Event Arguments:MapMouseEnterInteractiveOverlayEventArgs
MapKeyDown Occurs when key down on the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapKeyDown.28MapKeyDownInteractiveOverlayEventArgs.29
Event Arguments:MapKeyDownInteractiveOverlayEventArgs
MapKeyUp Occurs when key up on the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29
Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawing This event raises before the overlay is drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event raises after the overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.EditInteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
thinkgeo.mapsuite.wpfdesktopedition.editinteractiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
