thinkgeo.mapsuite.wpfdesktopedition.mapmouseupinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseUpInteractiveOverlayEventArgs
Provides data for the MapMouseUp event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseUpInteractiveOverlayEventArgs
MapMouseUpInteractiveOverlayEventArgs()
Constructor of MapMouseUpInteractiveOverlayEventArgs class.
MapMouseUpInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
This property gets the interaction auguments for the event args.
thinkgeo.mapsuite.wpfdesktopedition.mapmouseupinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
