thinkgeo.mapsuite.wpfdesktopedition.interactionarguments
ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments
This class encapsulates the information and simple method for interative actions.
    • ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments
InteractionArguments()
  • Constructor of InteractionArguments class.
  • Override the ToString API for object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ToString.28.29
  • Description:Returns a string to mark this instance and easy to read its properties.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MemberwiseClone.28.29
ScreenX
Gets or sets the screen X position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenX
  • Type:Single
ScreenY
Gets or sets the screen Y position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenY
  • Type:Single
WorldX
Gets or sets the world X position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldX
WorldY
Gets or sets the world Y position.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldY
MouseButton
Gets and sets which button is clicked on the map canvas.
CurrentExtent
Gets or sets the current extent used in the MapControl.
SearchingTolerance
Gets or sets the searching tolearance for tracking and editing.
MapWidth
Gets or sets the with for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapWidth
MapHeight
Gets or sets the height for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapHeight
DeltaManipulation
  • Type:ManipulationDelta
MapUnit
Gets or sets the unit for the Map Control.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapUnit
ZoomLevelSet
Gets or sets the ZoomLevelSet used in the Map Control.
MouseWheelDelta
Gets or sets the Mouse wheel delta used in the MouseWheel method in InterativeOverlay.
Scale
Gets or sets the scale in current status.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Scale
thinkgeo.mapsuite.wpfdesktopedition.interactionarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
