thinkgeo.mapsuite.formsedition.maptools
Table of Contents
ThinkGeo.MapSuite.FormsEdition.MapTools
<!– Class –> Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MapSuiteFormsEdition System.Collections.ObjectModel.Collection‹T›[[ThinkGeo.MapSuite.FormsEdition.MapTool * PublicKeyToken=null]] Culture=neutral * Version=9.0.0.0 MapSuiteFormsEdition *ThinkGeo.MapSuite.Core.GeoCollection‹T›[[ThinkGeo.MapSuite.FormsEdition.MapTool ThinkGeo.MapSuite.FormsEdition.MapTools
Public MethodMapTools Initializes a new instance of the class.
Public MethodMapTools MapToolsAdapter Initializes a new instance of the class.
Public PropertyAdapter MapElementAdapter Gets the adapter.
Public PropertyCenterCoordinate CenterCoordinateMapTool Gets or sets the center coordinate.
Public PropertyCount Int32 Collection<MapTool>
Public PropertyItem MapTool GeoCollection<MapTool>
Public PropertyItem MapTool Collection<MapTool>
Public PropertyZoomMapTool ZoomMapTool Gets the zoom map tool.
Protected PropertyItems IList<MapTool> Collection<MapTool>
MapTools()
Name Type Description
Go Back
MapTools(MapToolsAdapter)
adapter MapToolsAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolsAdapter –> The adapter.
Go Back
Add(String, MapTool)
Return Type Description
Void<!– System.Void –>
key String<!– System.String –>
item MapTool<!– ThinkGeo.MapSuite.FormsEdition.MapTool –>
<!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.FormsEdition.MapTool} –> Go Back
Add(MapTool)
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.FormsEdition.MapTool} –> Go Back
Add(MapTool)
Clear()
Contains(MapTool)
Boolean<!– System.Boolean –>
Contains(String)
CopyTo(MapTool[], Int32)
array MapTool[]<!– ThinkGeo.MapSuite.FormsEdition.MapToolthinkgeo.mapsuite.formsedition.maptools –>
index Int32<!– System.Int32 –>
GetEnumerator()
IEnumerator<MapTool><!– System.Collections.Generic.IEnumerator{ThinkGeo.MapSuite.FormsEdition.MapTool} –>
GetKeys()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
Type<!– System.Type –>
IndexOf(MapTool)
Insert(Int32, MapTool)
Insert(Int32, String, MapTool)
MoveDown(String)
MoveDown(MapTool)
MoveDown(Int32)
MoveTo(MapTool, Int32)
toIndex Int32<!– System.Int32 –>
MoveTo(String, Int32)
MoveTo(Int32, Int32)
fromIndex Int32<!– System.Int32 –>
MoveToBottom(MapTool)
MoveToBottom(Int32)
MoveToBottom(String)
MoveToTop(MapTool)
MoveToTop(String)
MoveToTop(Int32)
MoveUp(MapTool)
MoveUp(String)
MoveUp(Int32)
Remove(String)
Remove(MapTool)
RemoveAt(Int32)
ClearItems()
<!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.FormsEdition.MapTool}(overriden) –> Go Back
InsertItem(Int32, MapTool)
OnAdded(AddedGeoCollectionEventArgs)
e AddedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddedGeoCollectionEventArgs –>
OnAdding(AddingGeoCollectionEventArgs)
e AddingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.AddingGeoCollectionEventArgs –>
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
e ClearedItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearedItemsGeoCollectionEventArgs –>
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
e ClearingItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.ClearingItemsGeoCollectionEventArgs –>
OnCollectionChanged(NotifyCollectionChangedEventArgs)
e NotifyCollectionChangedEventArgs<!– System.Collections.Specialized.NotifyCollectionChangedEventArgs –>
OnInserted(InsertedGeoCollectionEventArgs)
e InsertedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertedGeoCollectionEventArgs –>
OnInserting(InsertingGeoCollectionEventArgs)
e InsertingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.InsertingGeoCollectionEventArgs –>
OnPropertyChanged(PropertyChangedEventArgs)
e PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –>
OnRemoved(RemovedGeoCollectionEventArgs)
e RemovedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovedGeoCollectionEventArgs –>
OnRemoving(RemovingGeoCollectionEventArgs)
e RemovingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.Core.RemovingGeoCollectionEventArgs –>
RemoveItem(Int32)
SetItem(Int32, MapTool)
Adapter
Gets the adapter.
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
<!– ThinkGeo.MapSuite.FormsEdition.MapTools –> Go Back
CenterCoordinate
Return Type
CenterCoordinateMapTool<!– ThinkGeo.MapSuite.FormsEdition.CenterCoordinateMapTool –>
Count
Return Type
Item
Return Type
Item
Return Type
ZoomMapTool
Return Type
ZoomMapTool<!– ThinkGeo.MapSuite.FormsEdition.ZoomMapTool –>
Items
Return Type
IList<MapTool><!– System.Collections.Generic.IList{ThinkGeo.MapSuite.FormsEdition.MapTool} –>
Added
Event Arguments
Event Arguments
Adding
Event Arguments
Event Arguments
ClearedItems
Event Arguments
Event Arguments
ClearingItems
Event Arguments
Event Arguments
CollectionChanged
Event Arguments
Event Arguments
Inserted
Event Arguments
Event Arguments
Inserting
Event Arguments
Event Arguments
PropertyChanged
Event Arguments
Event Arguments
Removed
Event Arguments
Event Arguments
Removing
Event Arguments
Event Arguments
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
thinkgeo.mapsuite.formsedition.maptools.txt · Last modified: 2017/03/16 21:59 (external edit)
