<!– Class –> Represents the zooming panel in the upper left corner of the map.
The zoom map tool consists of two zooming buttons.
ZoomMapTool | Initializes a new instance of the class. | ||
ZoomMapTool | ZoomMapToolAdapter | Initializes a new instance of the class. |
Adapter | MapElementAdapter | MapTool | Gets the adapter. |
GlobeExtent | RectangleShape | Gets or sets the globe extent. | |
IsEnabled | Boolean | MapTool | Gets or sets a value indicating whether this instance is enabled. |
IsGlobeButtonVisiable | Boolean | Gets or sets a value indicating whether this instance is globe button visiable. |
| adapter | ZoomMapToolAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.ZoomMapToolAdapter –> | The adapter. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.MapTool –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.FormsEdition.ZoomMapTool –> Go Back
